Hi all,
Is it possible to upgrade a high resolution dataset (created in ArcGIS 10.2) to an even higher resolution precision?
How might this be possible? How do you specify the resolution of a feature class if you are importing an XML schema?
The 'upgrade spatial reference' geoprocess tool only allows for low resolution datasets to be upgraded to high.
Upgrade spatial resolution doesn't give any suggestion other than upgrading to newer versions of arcmap
Upgrade dataset has similiar suggestions.
I assume you aren't trying to upgrade improve to a higher level than possible
