AnsweredAssumed Answered
Applying Heatmap Renderer to ArcGisDynamicMapServiceLayer
Question asked by danieljgalati on Apr 24, 2015
Latest reply on Dec 11, 2015 by gokuSan
Hello there,
I am attempting to apply a HeatMap renderer to a dynamic layer I have created. The DynamicLayer contains a point query gathered from my ArcGIS Server SDE database.
I have successfully implemented basic things such as SimpleRenderer to display the data on my map. However, whenever I attempt to use the same logic, but swap out the SimpleRenderer with HeatMapRenderer, I get errors. I am sure I am setting all parameters correctly as described in the Documentation Samples.
I am getting the following error reply from my ArcGIS Server: ":"Invalid renderer specified for dynamic dataLayer with 'id': 0."
My code is below: any help would be appreciated.
var dndSource, layerLookup, dynamicLayerInfos;
                (function() {
                    var layerName, dataSource, layerSource, options, drawingOptions;
                    debugger;
                    ///Testing Renderer
                    var heatmapRenderer = new HeatmapRenderer({
                        blurRadius: 10,
                        colorStops: [
                            { ratio: 0, color: "rgba(250, 0, 0, 0)" },
                            { ratio: 0.6, color: "rgb(250, 0, 0)" },
                            { ratio: 0.85, color: "rgb(250, 150, 0)" },
                            { ratio: 0.95, color: "rgb(255, 255, 0)" }],
                    var m_renderer = heatmapRenderer;
                    var m_queryDataSource = new QueryDataSource();
                    m_queryDataSource.workspaceId = biodWeb.const.gis.workSpaceID;
                    m_queryDataSource.geometryType = "point";
                    m_queryDataSource.oidFields = ["OBJECTID"];
                    m_queryDataSource.query = "Select OBJECTID, Shape from bioDWEB.BD.NATEARTH_10M_POPULATED_PLACES";
                    m_queryDataSource.spatialReference = new SpatialReference({ wkid: 102100 });
                    var layerSource = new LayerDataSource();
                    layerSource.dataSource = m_queryDataSource;
                    //---------- Dynamic layer
                    layerName = "add a new layer from database";
                    var usaLayer = new ArcGISDynamicMapServiceLayer("http://MYSERVER.COM/arcgis/rest/services/BiodWebDyn/BioD_DynamicMap/MapServer",
                    { "id": "NEW LAYER" });
                    usaLayer.setVisibleLayers([0]);
                    if (!dynamicLayerInfos) {
                        dynamicLayerInfos = usaLayer.createDynamicLayerInfosFromLayerInfos();
                    var dynamicLayerInfo = new DynamicLayerInfo();
                    dynamicLayerInfo.id = 0;
                    dynamicLayerInfo.name = layerName;
                    dynamicLayerInfo.source = layerSource;
                    dynamicLayerInfos.push(dynamicLayerInfo);
                    usaLayer.setDynamicLayerInfos(dynamicLayerInfos, true);
                    drawingOptions = new LayerDrawingOptions();
                    drawingOptions.renderer = m_renderer;
                    options = [];
                    options[0] = drawingOptions;
                    usaLayer.setLayerDrawingOptions(options);
                    map.addLayer(usaLayer);
Outcomes
