fakerudy
QueryTask using tokens
Discussion created by fakerudy on Oct 25, 2010
Latest reply on Apr 5, 2012 by GeorgePan
Is it possible to use a token with a single layer url in Javascript API? More specifically, with esri.tasks.QueryTask()?
For example, if I have a token:
var token = 123456
and place it at the end of a single layer url:
dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://mywebsite/ArcGIS_AD/rest/services/AD_All/Map_Service/MapServer/1?token=" + token);
it does not work.
However, in cases such as esri.layers.ArcGISDynamicMapServiceLayer, I can work around it by using:
dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://mywebsite/ArcGIS_AD/rest/services/AD_All/Map_Service/MapServer/?token=" + token);
var visibleLayers = [1];
dynamicLayer.setVisibleLayers(visibleLayers);
map.addLayer(dynamicLayer);
This works great with esri.layers.ArcGISDynamicMapServiceLayer() and esri.tasks.FindTask(), but I'm unable to find a workaround for esri.tasks.QueryTask().
It appears that I have to use the single layer url for QueryTask, which seems to be a problem when using tokens (see first example):
esri.tasks.QueryTask("http://mywebsite/ArcGIS_AD/rest/services/AD_All/Map_Service/MapServer/1");
Does anyone know of a work around for esri.tasks.QueryTask() when using tokens?
Thank you!
Outcomes
