How to change lods of map when change layers of map
3542
04-23-2015 09:37 PM
lasinh
New Contributor III
I have 2 ArcGISTiledMapServiceLayer services and cached with different scales. a ArcGISTiledMapServiceLayer services  cached with scales(1000000, 500000, 200000, 100000, 50000, 20000, 10000). other ArcGISTiledMapServiceLayer  cached(12500000, 2000000, 1000000). how to change myMap  when change ArcGISTiledMapServiceLayer services
khairulamri
khairulamri
here is the example from esri :
https://developers.arcgis.com/javascript/jssamples/map_switch_layer_on_zoom.html
hope this helps
Amri
lasinh
New Contributor III
no, when change service map , change scalebar  of map?
khairulamri
what if get the extent based on map service, esri/graphicsUtils | API Reference | ArcGIS API for JavaScript
after that, zoom the map to the updated mapservice using map.setExtent
