Enable Supports Pagination = true at 10.3
3139
04-23-2015 02:07 PM
DavidColey
Hi-
We are combing over the REST, ADMIN and the JSAPI in vain trying to figure out how to set 'supports Pagination : true' for our 10.3 dynamic map services.   If you look at:
https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/3
in the arcgisonline rest you can clearly see that under Advanced Query section that supportsPagination is true.  How do I enable that on my 10.3 services?
My sample service at:
https://scggisap1dw.bcc.scgov.local:6443/arcgis/rest/services/ScOperational/PropertySearch/MapServer...
appears to me to be exactly the same except supportsPagination is false.
David
DavidColey
Sorry - should have searched a little more.  The post:
How do you enable the "Supports Pagination" on a layer at 10.3?
shows that it is the FileGDB at 10.3 that does not support pagination, and only certain RDBMS' do, like SQLServer at 2012, but not at 2008.  So I will mark my question as assumed answered, but this really is a large bug -  esp when we are all supposed to be publishing from locally sourced fgdbs!
David
