ITextElement : ArcObject C# Visual Studio 10 - Arcgis 10.1
3565
04-22-2015 07:44 AM
Jose_LuisGarcinuno-Oporto
New Contributor III
                 The Idea is add a Text to the map, it is working fine except the COLOR, it does not take the Color defined in pRGBcolor object.
                    IRgbColor pRgbcolor = new RgbColorClass();
                    pRgbcolor.Blue = 0;
                    pRgbcolor.Green = 255;
                    pRgbcolor.Red = 0;
                    IMask pMask = new TextSymbolClass();
                    pMask.MaskStyle = esriMaskStyle.esriMSHalo;
                    pMask.MaskSize = 2;
                    ITextElement pTextElement = new TextElementClass();
                    IElement pElement = pTextElement as IElement;
                    pElement.Geometry = pPagePt;
                    ITextSymbol pTextSymbol = new TextSymbolClass();
                    pTextSymbol.Color = pRgbcolor;
                    pTextSymbol = pMask as ITextSymbol;
                    pTextElement.Symbol = pTextSymbol as ITextSymbol;
                    pTextElement.Text = "Test";
                    pGraphicCont.AddElement(pElement, 0);
                    pMxDoc.ActivatedView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null);
ChrisKushnir
New Contributor III
You are creating two TextSymbols, setting the color on the second, then throwing the second away with:
ChrisKushnir
New Contributor III
New Contributor III
pRgbcolor.Blue = 0;
pRgbcolor.Green = 0;
pRgbcolor.Red = 255;
pMask.MaskSize = 2;
pTextElement.Symbol = pTextSymbol;
pTextElement.Text = a;
pElement.Geometry = pLoc;
null, null);
Thanks Chris, I ended up with this code and its works.
ChrisKushnir
New Contributor III
You're still creating then throwing away the second instance.
Change::
To:
ITextSymbol pTextSymbol = pMask as ITextSymbol;
