Hi-
I am creating density maps from polygons (.shp), which has involved many time consuming steps and I was hoping to simlify the process. I have been taking each polygon, giving it a value of one then converting it to raster, adding the raster layers together, converting it to a point layer, then using Spatial Analysis to run a density analysis. I'm working with about 5,000 polygons, so you can see that this is way too much work. There has got to be an easier way! Is there a way that I can take a .shp with many overlaping polygons and giving each a value of one add them together, then create a raster from that? Or any other ideas?
-Thanks
