rrupp
Can't delete DBF field from ArcMap 10 table view window
Discussion created by rrupp on Oct 20, 2010
Latest reply on Dec 13, 2011 by BahamutZ
If I try to delete a field from either a shapefile or standalone .dbf table using the table view window (right click on field heading > delete) nothing happens. All other functions (e.g. add field, field calculator) work fine. I've tried this with several tables on different computers with the same result. Geodatabase tables function as expected. The work around is to delete the field from the properties window in Catalog.
Anyone else seen this?
Regards, Rick
Outcomes
