Hi every1,
My task is to compare the attributes of two shape files.
my code(which is shown below)works fine on small data.no issues but if i have shapefiles of lets say 5000 records it takes a very long time.I want my tool to work on lacs of records with a very fast speed.can any1 help me with the solution.
my code is:
//using System;
//using System.Collections.Generic;
//using System.Text;
//namespace blobcompare
// public class Class1
using System;
using System.ComponentModel;
using System.Data;
//using System.Drawing;
using System.Text;
using System.Windows.Forms;
using ESRI.ArcGIS.ArcMapUI;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Framework;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.SystemUI;
using System.Runtime.InteropServices;
using ESRI.ArcGIS.ADF.CATIDs;
using ESRI.ArcGIS.Geodatabase;
using ESRI.ArcGIS.Controls;
using System.IO;
[Guid("cc38d134-fe98-41e5-989f-dc36d8d9caba")]
[ClassInterface(ClassInterfaceType.None)]
[ProgId("blobcompare.Class1")]
[ComVisible(true)]
public class Class1 : ICommand
//private IHookHelper m_hookHelper = null;
[System.Runtime.InteropServices.DllImport("gdi32.dll")]
static extern bool DeleteObject(IntPtr hObject);
#region "Component Category Registration"
[ComRegisterFunction()]
static void Reg(string regKey)
MxCommands.Register(regKey);
[ComUnregisterFunction()]
static void Unreg(string regKey)
MxCommands.Unregister(regKey);
#endregion
public ILayer layer1;
public ILayer layer2;
public IMxApplication mxApplication; //to create application display object
IApplication m_application;
private IntPtr m_hBitmap;
public IApplication m_app1;
public IApplication m_app;
public IMxDocument m_mxDoc;
public MxDocument m_mxDocument;
public Map m_map;
public PageLayout m_pageLayout;
//private System.Windows.Forms.Button button1;
public IFeatureClass featureClass;
//public TextWriter txt = new StreamWriter("abc.txt");
private bool m_enabled;
#region ICommand Members
public string Message
get
// Set the message string that appears in the statusbar of the
// application when the mouse passes over the command.
return "Compare";
//return null;
public int HelpContextID
get
return 0;
public string Name
get
return "Compare";
//return null;
public void OnClick()
IActiveView activeView = m_mxDoc.ActiveView;
int count = 0;
layer1 = m_map.get_Layer(0);
layer2 = m_map.get_Layer(1);
try
IFeatureLayer pfl = (IFeatureLayer)layer1;
IFeatureLayer pfl1 = (IFeatureLayer)layer2;
IFeatureClass featureClass = pfl.FeatureClass;
IFeatureClass featureClass1 = pfl1.FeatureClass;
IFeatureCursor featureCursor = featureClass.Search(null, true);
IFeature Feat = featureCursor.NextFeature();
int count1 = 0;
int feildval1 = featureCursor.FindField("BUILDINGID");
int feildval2 = featureCursor.FindField("BLOCKID");
int feildval3 = featureCursor.FindField("ROOFTYPE");
int feildval4 = featureCursor.FindField("ROOFSUB");
int feildval5 = featureCursor.FindField("ARCHTYPE");
int feildval6 = featureCursor.FindField("RIDGE_HT");
int feildval7 = featureCursor.FindField("EAVE_HT");
int feildval8 = featureCursor.FindField("Area");
int feildval9 = featureCursor.FindField("minZ");
string errvals = "FID=";
while (Feat != null)
count = 0;
IFeatureCursor featureCursor1 = featureClass1.Search(null, true);
IFeature Feat1 = featureCursor1.NextFeature();
string buid = Feat.get_Value(feildval1).ToString();
int blkid = Convert.ToInt16(Feat.get_Value(feildval2));
int rftp = Convert.ToInt32(Feat.get_Value(feildval3));
int rfsub = Convert.ToInt32(Feat.get_Value(feildval4));
string arc = Feat.get_Value(feildval5).ToString();
double ridge = Convert.ToDouble(Feat.get_Value(feildval6));
double eave = Convert.ToDouble(Feat.get_Value(feildval7));
double area = Convert.ToDouble(Feat.get_Value(feildval8));
double minz = Convert.ToDouble(Feat.get_Value(feildval9));
while (Feat1 != null)
string buid1 = Feat1.get_Value(feildval1).ToString();
int blkid1 = Convert.ToInt16(Feat1.get_Value(feildval2));
int rftp1 = Convert.ToInt32(Feat1.get_Value(feildval3));
int rfsub1 = Convert.ToInt32(Feat1.get_Value(feildval4));
string arc1 = Feat1.get_Value(feildval5).ToString();
double ridge1 = Convert.ToDouble(Feat1.get_Value(feildval6));
double eave1 = Convert.ToDouble(Feat1.get_Value(feildval7));
double area1 = Convert.ToDouble(Feat1.get_Value(feildval8));
double minz1 = Convert.ToDouble(Feat1.get_Value(feildval9));
if ((buid == buid1) && (blkid == blkid1) && (rftp == rftp1) && (arc == arc1) && (ridge == ridge1) && (eave == eave1) && (minz == minz1) && (area==area1))
count++;
//MessageBox.Show("Count " + count.ToString());
break;
else
errvals += Feat1.OID.ToString() + " or FID=";
if (count < 1)
//txt.WriteLine("values did not match " + Feat.get_Value(feildval1).ToString());
m_map.SelectFeature(layer1, Feat);
//m_map.SelectFeature(layer1, Feat);
activeView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, null, null);
catch
MessageBox.Show("Error");
MessageBox.Show("done");
public int Bitmap
get
return m_hBitmap.ToInt32();
public void OnCreate(object hook)
m_app = hook as IApplication;
m_mxDoc = m_app.Document as IMxDocument;
m_mxDocument = m_app.Document as MxDocument;
m_map = m_mxDoc.FocusMap as Map;
public string Caption
get
return "Compare";
//return null;
public string Tooltip
get
// Set the string that appears in the screen tip.
return "Compare";
//return null;
public bool Checked
get
return false;
public bool Enabled
get
// Add some logic here to specify when the command should
// be enabled. In this example, the command is always enabled.
return true;
public string HelpFile
get
return null;
public string Category
get
// Set the category of this command. This determines where the
// command appears in the Commands panel of the Customize dialog.
return "Compare";
//return null;
#endregion
