yosie212
move layer up and down doesn't work
Discussion created by yosie212 on Oct 16, 2010
I???m writing code with vba to build tool layer order (move layer up and down), switch from data view to layout view conversely, and turn on and off layer. I have 2 layers named river and lake.  What I want is in data view: the position of layer (0) is river and lake is invisible. And in layout view: the position of layer (0) is lake and river is invisible. The result is layer only move one time every after opening file mxd, whatever the selected layer is, the 2nd run and so on only switching and turning on or off layer. And surprisingly, although the layer lake is invisible but I can see in layout view.
Below are my code and no error. Could anyone please tell me where the mistake is?
Yosie
Private Sub MoveLayerDown_Click()
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pSelLayer As ILayer
Set pSelLayer = pDoc.SelectedLayer
Dim pMap As IMap
Set pMap = pDoc.FocusMap
Dim i As Long
Dim layerIndex As Long
For i = 0 To pMap.LayerCount - 1
    If pMap.Layer(i).Name = pSelLayer.Name Then
        layerIndex = i
    End If
Next i
pMap.MoveLayer pSelLayer, layerIndex + 1
Call View
Call OnOff
End Sub
Private Sub MoveLayerUp_Click()
Dim pMap As IMap
Dim i As Long
        layerIndex = i
    End If
Next i
pMap.MoveLayer pSelLayer, layerIndex - 1
Call View
Call OnOff
End Sub
Private Sub View()
Dim pMap As IMap
Dim pLayer As ILayer
If pMap.Layer(0).Name = "Soil" Then
    Set pDoc.activeView = pDoc.FocusMap
Else
    Set pDoc.activeView = pDoc.pageLayout
End If
End Sub
Private Sub OnOff()
Dim pMap As IMap
pMap.Layer(0).Visible = True
pMap.Layer(1).Visible = False
End Sub
Outcomes
