hotspot analysis fails to execute
745
10-15-2010 02:07 AM
KerstinKober
I tried to execute a hotspot analysis which so far always worked. Now I received this error message:
"Executing (HotSpots_4): HotSpots 710br_data_C1 710_br_cde F:\Offshore\EXTRA18_trials_for_more_regional_approach\Foraging_ranges_around_breeding_colonies_top_GO\foraging_range_plus_autocorr\710_br\test1.shp "Inverse Distance" "Euclidean Distance" Row 60000 # # GiUnknown
Start Time: Fri Oct 15 11:02:35 2010
Running script HotSpots...
Building Lists...
Computing Weights...
                   20% complete
                   40% complete
                   60% complete
                   80% complete
                   100% complete
                  100% complete
Calculating results...
                   20% complete
                   40% complete
                   60% complete
                   80% complete
                  100% complete
Error in script HotSpots.
Error in executing: cmd.exe /C D:\programs\ArcGIS\ARCTOO~1\Scripts\Gi.py  "710br_data_C1" "710_br_cde" "F:\Offshore\EXTRA18_trials_for_more_regional_approach\Foraging_ranges_around_breeding_colonies_top_GO\foraging_range_plus_autocorr\710_br\test1.shp" "Inverse Distance" "Euclidean Distance" "Row" "60000" "#" "#" "GiUnknown"
Failed to execute (HotSpots_4).
End Time: Fri Oct 15 11:03:10 2010 (Elapsed Time: 35.00 seconds)"
Any idea what I did wrong this time?
Kerstin
KerstinKober
Great, that solved indeed the problem and everything is back to normal!
Thanks a lot!!!
Kerstin
AnnDonald
What was the solution?
Thanks!
