How to add Tiled service as layer
3814
04-15-2015 08:15 AM
WalterEralio
New Contributor III
I'll like to add this service
https://rest.parcelatlas.com/Tiles/D3342484-32CD-DD11-AF04-0003FF70C8AE/0320210202001111
(description here: https://rest.parcelatlas.com/HowTo.aspx  )
  1. Tiles by Quad Key
    /Tiles/{contract ID}/{quad key}
    Example: /Tiles/D3342484-32CD-DD11-AF04-0003FF70C8AE/0320210202001111
    A quad tile image showing parcels, suitable for use in a Microsoft Bing Maps application or other mapping application.
as another layer .. can that be done? I know it can be added with Virtual Earth  like
http://www.parcelatlas.com/ParcelAltasServices/
Any idea or hint?
Tags (1)
KellyHutchins
Esri Frequent Contributor
Take a look at the WebTiledLayer class - it allows you to add map tiles to a map.  Here's a link to a sample showing how this class works:
Web tiled layer - many layers | ArcGIS API for JavaScript
WalterEralio
New Contributor III
I checked it but couldn't figure the quadtree parameter nor where to put the contractID etc.. will keep trying
WalterEralio
New Contributor III
Sorry to bother you since you are the only one to reply.. checking the info I cannot figure out if the service provided by parcelatlas has all the features I need to setup as a web tiled layer..
Do I have to set the parameters like the contractID as part of attributes?
I have 2 different options to access the data:
(https://rest.parcelatlas.com/HowTo.aspx  like)
and
as a layer over bing maps
   <head>
   <title></title>
   <script type="text/javascript" src="http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.2"></script>
   <script type="text/javascript">
  var map = null;
  var tileLayer;
  function GetMap()
  map = new VEMap('myMap');
  map.LoadMap(new VELatLong(30.52,-84.37),17,'r' ,false);
  GetTiles();
  function GetTiles()
  var bounds = [new VELatLongRectangle(new VELatLong(32,-85),new VELatLong(30,-83))];
  var tileSourceSpec = new VETileSourceSpecification("Parcel", "MapTileHandler.ashx?qkey=%4&contractid=D3342484-32CD-DD11-AF04-0003FF70C8AE");
  tileSourceSpec.NumServers = 1;
  tileSourceSpec.Bounds = bounds;
  tileSourceSpec.MinZoomLevel = 10;
  tileSourceSpec.MaxZoomLevel = 18;
  tileSourceSpec.Opacity = 1;
  tileSourceSpec.ZIndex = 100;
  map.AddTileLayer(tileSourceSpec, true);
  function DeleteTileLayer()
  map.DeleteTileLayer("Parcel");
   </script>
</head>
I might be a little confused where to start reading/finding out how to access this using the javascript api
