i try to remove a group layer with arcpy for several mxd's with this code:
import arcpy,os,sys import arcpy.mapping from arcpy import env env.workspace = r"D:\PROJECTS\atar_ashpa_depo\gis" for mxdname in arcpy.ListFiles("*.mxd"): print mxdname # print list of mxd's in the folder mxd = arcpy.mapping.MapDocument(r"D:\PROJECTS\atar_ashpa_depo\gis\\" + mxdname) dfList = arcpy.mapping.ListDataFrames(mxd, "*") for df in dfList: for lyr in arcpy.mapping.ListLayers(mxd, "", df): if lyr.GroupLayer.name == "segment-BL.dwg Group Layer": arcpy.mapping.RemoveLayer(df, lyr) print 'RemoveLayer 3' mxd.save() del mxd
but get en error:
land use map Traceback (most recent call last): File "C:\yaron\shonot\software\gis\tools\YARON_SCRIPTS\RemoveLayer by name with 2 df option 1.py", line 35, in <module> if lyr.GroupLayer.name == "segment-BL.dwg Group Layer": AttributeError: 'Layer' object has no attribute 'GroupLayer' >>>
thanks for any help
Solved! Go to Solution.
First check if your layer is a group layer and after check if this name match with your search name.
See code below:
import arcpy,os,sys import arcpy.mapping from arcpy import env env.workspace = r"D:\PROJECTS\atar_ashpa_depo\gis" for mxdname in arcpy.ListFiles("*.mxd"): print mxdname # print list of mxd's in the folder mxd = arcpy.mapping.MapDocument(r"D:\PROJECTS\atar_ashpa_depo\gis\\" + mxdname) dfList = arcpy.mapping.ListDataFrames(mxd, "*") for df in dfList: for lyr in arcpy.mapping.ListLayers(mxd, "", df): if lyr.isGroupLayer: if lyr.name == "segment-BL.dwg Group Layer": arcpy.mapping.RemoveLayer(df, lyr) print 'RemoveLayer 3' mxd.save() del mxd
Have fun,
Fred
See code below:
Have fun,
Fred
thanks Fred !!!
