SDE - SQL where is Dataset info stored
3301
04-10-2015 11:12 AM
DaveOrlando
Occasional Contributor III
I'm trying to track down a table that stores the Dataset info.
following this post, How to determine current edit session locking a version?​  ,
I'm trying something similar, but want to trace the tables back to their Dataset. How can I add to this query to do that? I can't seem to find Dataset info anywhere in the sql tables.
SELECT
v.name as version_name,
pri.owner as data_owner,
tr.table_name,
tl.*
FROM sde.sde_versions v
JOIN sde.SDE_state_locks sl ON sl.state_id = v.state_id
JOIN sde.SDE_process_information pri ON pri.sde_id = sl.sde_id
JOIN sde.sde_table_locks tl ON tl.sde_id = pri.sde_id
JOIN sde.sde_table_registry tr ON tr.registration_id = tl.registration_id
order by lock_time desc
Dave
SamuelTompsett
It would be this link for SQL Server:
ArcGIS Help 10.1
SamuelTompsett
Hi Dave,
You can find the Feature Dataset information from the "GDB_" tables. You will have to do a few table joins to get the wanted information.
ArcGIS Help 10.1
Hopefully that helps!
-Sam
SamuelTompsett
ArcGIS Help 10.1
DaveOrlando
Here is the query I wrote to list Feature Classes and their associated Datasets.
select items_a.Name as FeatureClass, items_b.Name as DataSet
from sde.GDB_ITEMS items_a
join sde.GDB_ITEMRELATIONSHIPS rels on rels.DestID = items_a.UUID
join sde.GDB_ITEMS items_b on items_b.UUID = rels.OriginID
join sde.GDB_ITEMTYPES types_a on types_a.UUID = items_a.Type
join sde.GDB_ITEMTYPES types_b on types_b.UUID = items_b.Type
where types_a.Name = 'Feature Class' and types_b.Name = 'Feature Dataset'
order by DataSet, FeatureClass
now I have to combine it with the query at the top to just list the data that is causing locks.
