call addFeature with geometry for a featureserver
3458
04-10-2015 02:59 PM
billzhang
I have a featureServer defined. In invoked addFeature call with the following information including the geometry which I set to longitude and latitude. This place should be in Hawaii area. However, after I added this layer to a map, this point showed up in Africa. I looked at the point that showed up in Hawaii, its x and y showed a big x and y. Both examples are shown below. So what should I put in the geometry field in my request?
Point showed up in Africa which should have shown in Hawaii
Request:
"geometry" : {
        "x" : -155.445052,
        "y" : 19.550263
+++++++++++++++++++++++++++Response:
WorkOrderNo:    9997
WorkOrderDesc:    1750 Kaumana Drive
Priority:    2
LATITUDE:    19.550263
LONGTITUDE:    -155.445052
geometry
Point:
X: 19.550263
Y: -155.445052
Point that shows in Hawaii showed X Y value like these.
X: -17304064
Y: 2205688
OwenEarley
Occasional Contributor III
The coordinates are most likely Web Mercator. If you are using the Javascript API you can use the geographicToWebMercator() function to convert your geographic coordinates before sending the addFeature request.
