When publishing a map service there are 4 Item Descriptions that get auto-populated from the MXD's map properties. But there is a fifth Item Description called "Access and Use Constraints" that is blank. I've been filling this out using the ArcGIS Server Manager but I don't see that field displayed in the rest end point. So it looks like it is a waste of time populating it if it's only visible through ArcGIS Server Manager. FYI, we are running Server 10.2.2.
