AnsweredAssumed Answered
Barriers for cross country routing
Question asked by lyap8408 on Apr 8, 2015
Latest reply on Apr 9, 2015 by lyap8408
I had created a cost-surface raster, and am intending to use Path distance to resolve the least cost path.
I would like to add barriers as a factor in considering the routing problem. Barriers will be combined into the cost-surface raster, represented as null values.
This program will be accessed by ArcGIS Runtime .NET API, where setting barriers will mimic something alike RouteParameters.SetPolygonBarrier(IEnumerable<Graphics>).
I am having a problem:
- defining barriers in ArcMap, so that they will be represented as Null values in the cost surface. I had tried something below, but after quite a bit of effort it seems not to be the best way.
Please advice on any other workarounds, or missing key things in my following half-a-solution. Thanks!
Tried method:
1) Converting barrier features as raster (Feature to Raster). Value of barriers features in the raster is represented as 0
2) Using Cell Statistic to select Minimal value from Barrier raster and Cost-Surface.
3) Finally using Set Null tool to set values = 0 as Null (NoData).
Lol, however, despite all these steps, the output raster is too small and is not the original extent of the cost-surface and is insufficient to for Path Distance tool. Ie: extent of the output raster only encompasses the extent of the barrier features.
Outcomes
