AnsweredAssumed Answered
Error in initializing role store arcgis
Question asked by swall on Apr 7, 2015
I have a Windows 2008 R2 Standard server setup with ArcGIS Server 10.2.2.  This server hosts several sites and a few of these sites have SQL Server Express security enabled.  These sites have been configured using Geocortex and proxied using Apache.
For quite some time now, whenever I try to access these secure sites, I need to enter my credentials multiple times before I can finally load the site successfully.  I do not change any settings during this time, just refresh the browser and login again.  Looking at the logs, I see an error message from early this morning, likely after windows updates have been installed and/or a reboot has occurred.  Below is a snippet from the server log.  The remainder of the log has the 6581 code repeated.  After say 5 attempts of logging into the site, it mysteriously works and is usually ok for the rest of the day.  I would appreciate any advice as to what may be causing this behavior and tips about where to look to troubleshoot further.
And a possibly related issue, the c drive on this server (and similar servers with ArcGIS Server installed) is becoming full and running out of disk space.  Any ideas as to why this is happening?  Nothing seems to be growing too large.  Are there any log files that I should be checking and/or deleting?
<Msg time="2015-04-07T05:21:13,541"
type="WARNING" code="7113" source="Admin"
process="1244" thread="1" methodName=""
machine="servername" user="" elapsed="">The
application server configuration was found to be corrupted. Beginning
repair.</Msg>
<Msg time="2015-04-07T06:22:40,588"
type="WARNING" code="8520" source="Server"
process="2404" thread="1" methodName=""
elapsed="">Error in initializing role store. Error unmarshaling
return header; nested exception is:
               java.net.SocketException:
Connection reset</Msg>
<Msg time="2015-04-07T08:46:42,232"
type="SEVERE" code="6581" source="Admin"
elapsed="">Failed to validate user credentials for the user
'username'. java.rmi.UnmarshalException: Error unmarshaling return header;
<Msg time="2015-04-07T09:06:39,66"
Thanks in advance for your help,
Sharon
Outcomes
