Problem regarding search coordinates on the map
3950
5
04-05-2015 12:10 AM
thilibu
I want to identify the coordinates by tapping  a point on the map.Here is my code snippet.
      mMapView.setOnSingleTapListener(new OnSingleTapListener() {
            private static final long serialVersionUID = 1L;
            public void onSingleTap(float screenX, float screenY) {
                mLocationLayer2.removeAll();
                Point mapPoint = mMapView.toMapPoint(screenX, screenY);
               // Point pnt = (Point) GeometryEngine.project(mapPoint, mMapView.getSpatialReference(), SpatialReference.create(4326));
               SimpleMarkerSymbol sms = new SimpleMarkerSymbol(Color.YELLOW,15, SimpleMarkerSymbol.STYLE.X);
               TextSymbol txtSym = new TextSymbol(20, String.valueOf(mapPoint), Color.RED);
               txtSym.setOffsetX(10);
                Graphic gMarker = new Graphic(mapPoint, sms);
                Graphic gText = new Graphic(mapPoint, txtSym);
                mLocationLayer2.addGraphics(new Graphic[] { gMarker, gText });
Here when tapped on the map, appears a text symbol with  "Point[m_attributes[8966832.811,663665.135],m_description=com.esri.geometry.VertexDescription@7c5d0f85]"
But only i want to  appear coordinates on the map. So how can i do that?
Please help me on this.. Thank you
EricBader
Occasional Contributor III
Ah. It looks like you're getting the toString() representation of the Point geometry as your label text.
" TextSymbol txtSym = new TextSymbol(20, String.valueOf(mapPoint), Color.RED);"
You can explicitly construct the text for the label from getting the X and Y attributes of the Point geometry itself.
For example, do something like:
String labelText = mapPoint.getX() + " , " + mapPoint.getY();
Then:
"TextSymbol txtSym = new TextSymbol(20, labelText, Color.RED);"
See what I mean?
Hope this helps.
EricBader
Are you saying that your text graphic is not showing up on the Map?
thilibu
Thank you for the reply..No.. that's show on the map. I only want to show coordinates of the tapped point. But here shows unnecessary things.
Here is the text that shows on text graphic:  "Point[m_attributes[8966832.811,663665.135],m_description=com.esri.geometry.VertexDescription@7c5d0f85]"
But i only want to see 8966832.811, 663665.135 on the text graphic.
thilibu
Hello... i'm waiting for the answer
EricBader
Then:
See what I mean?
Hope this helps.
thilibu
Thank you soo much..
