Story map settings
4122
5
04-03-2015 10:56 AM
BartoszBrzeziński1
New Contributor III
Hi!
I have problem with story map settings. I`im trying change logo in header (esri logo for my own). My .jpg has proper size an it hosted on Flickr/Picasa. When i`m pasting ulr photo nothing happened ;/ Have you got any ideas? Thanks a lot for yours help/
RupertEssinger
There is an issue in the dialog I have noticed and have submitted as a bug report: sometimes the URL you enter for a custom logo is ignored when you press Apply,
It always accepts the URL if you paste the URL in, then press Enter, then press Apply. Try that and I think it will work for you.
RupertEssinger
Which Story Map application template are you using? There are several of these
DylanBaier
Hi, I am having the same problem using the Map Series builder. When I switch it to my logo URL and hit apply it just changes to the ESRI logo. Thanks.
RupertEssinger
DylanBaier2
Thanks, that worked.
BartoszBrzeziński1
New Contributor III
Thanks a lot.
