Dijit BasemapToggle Kills Map?
3993
04-01-2015 03:28 PM
LauraMiles1
Occasional Contributor III
I'm VERY new to the ArcGIS javascript API. I'm trying to get two ESRI samples to work together:
Toggle layer visibility | ArcGIS API for JavaScript
Basemap Toggle | ArcGIS API for JavaScript
I've got Toggle layer visibility working fine, but when I try to add in Basemap Toggle things go sideways and I don't know enough about the API to know why. Soon as I add in the reference esri/dijit/BasemapToggle, the map itself disappears. Here's my code:
<code>
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Maps on Request</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
  <style>
   html, body, #map {
     padding: 0;
     margin: 0;
     height: 100%;
   #TOC {
   position: absolute;
   font-family: verdana, helvetica, arial;
   margin: 5px;
   padding: 25px;
   padding-left: 75px;
   z-index: 50;
   #BasemapToggle {
   position: absolute;
   top: 20px;
   right: 20px;
   z-index: 50;
  </style>
    <script src="http://js.arcgis.com/3.13/"></script>
    <script>
      var map;
      require([
     "esri/dijit/BasemapToggle",
        "esri/map",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/ImageParameters",
        "dojo/dom",
        "dojo/on",
        "dojo/query",
        "dojo/domReady!"
        function (Map, ArcGISDynamicMapServiceLayer, ImageParameters, BasemapToggle, dom, on, query) {
          var layer, visibleLayerIds = [];
          map = new Map("map", {
  basemap: "topo"
          //Use the ImageParameters to set the visibleLayerIds layers in the map service during ArcGISDynamicMapServiceLayer construction.
          var imageParameters = new ImageParameters();
   //This layer is visible on startup
          imageParameters.layerIds = [0];
          imageParameters.layerOption = ImageParameters.LAYER_OPTION_SHOW;
          //can also be: LAYER_OPTION_EXCLUDE, LAYER_OPTION_HIDE, LAYER_OPTION_INCLUDE
          layerCadastral = new ArcGISDynamicMapServiceLayer("http://cop-gis4:6080/arcgis/rest/services/MOR/MOR_Cadastral_WGS1984/MapServer",
            {"imageParameters": imageParameters});
          map.addLayer(layerCadastral);
          on(dom.byId("layer0CheckBox"), "change", updateLayerVisibility);
          on(dom.byId("layer1CheckBox"), "change", updateLayerVisibility);
   on(dom.byId("layer2CheckBox"), "change", updateLayerVisibility);
          function updateLayerVisibility () {
            var inputs = query(".list_item");
            var inputCount = inputs.length;
            //Dummy layer - is there a workaround? Setting this to an actual layer means it can't be turned off
            visibleLayerIds = [1001];
            for (var i = 0; i < inputCount; i++) {
              if (inputs.checked) {
                visibleLayerIds.push(inputs.value);
            if (visibleLayerIds.length === 0) {
              visibleLayerIds.push(-1);
            layerCadastral.setVisibleLayers(visibleLayerIds);
   var toggle = new BasemapToggle({
  map: map,
  basemap: "satellite"
  }, "BasemapToggle");
  toggle.startup();
    </script>
  </head>
  <body>
    <div id="TOC" Layer List:<br>
  <input type='checkbox' class='list_item' id='layer0CheckBox' checked value=0 />VFPA Boundary<br>
  <input type='checkbox' class='list_item' id='layer1CheckBox' value=3 />Municipal Boundaries<br>
        <input type='checkbox' class='list_item' id='layer2CheckBox' value=7 />Lots (zoom in)<br>
    </div>
    <div id="map"></div>
  <div id="BasemapToggle">BasemapToggle</div>
  </body>
</html>
</code>
SteveCole
More than likely, the issue lies with the specified order of widgets in your code:
require([
        "esri/map",
        "dojo/dom",
        "dojo/on",
        "dojo/query",
        "dojo/domReady!"
        function (Map, ArcGISDynamicMapServiceLayer, ImageParameters, BasemapToggle, dom, on, query) {.....
Change it to this and see what happens:
require([
        "esri/map",
        "dojo/dom",
        "dojo/on",
        "dojo/query",
        "dojo/domReady!"
In the function() declaration, basemapToggle must be in the same position specified as part of the reuire([..]) statement.
SteveCole
require([
        "esri/map",
        "dojo/dom",
        "dojo/on",
        "dojo/query",
        "dojo/domReady!"
require([
        "esri/map",
        "dojo/dom",
        "dojo/on",
        "dojo/query",
        "dojo/domReady!"
LauraMiles1
That was it - thank you Steve!
