Routing Parameter: OutputLine
3888
03-31-2015 11:50 PM
LinaYap1
I am using ArcGIS Runtime for .NET 10.2.4, and doing LocalRouteTask with a .geodatabase file.
Geodatabase file, cost attribute is Length (Meters)
I was testing the behaviour for RouteParameters.OutputLine which seems a little different from expectation based on the documentation
Basic Config:
RouteParameters routeParam = await routeTask.GetDefaultParametersAsync();
routeParam.OutSpatialReference = MapView.SpatialReference;
routeParam.ReturnRoute = true;
routeParam.ReturnDirections = true;
routeParam.DirectionLengthUnits = LinearUnits.Kilometers;
routeParam.DirectionLanguage = new CultureInfo("en-US");
routeParam.SetStops(stops);
routeParam.ReturnStops = true;
routeParam.ImpedanceAttributeName = "Length";
Varying Setting:
routeParam.OutputLine = Default
Observation: RouteResult is always null.
routeParam.OutputLine = Straight
Observation: RouteResult returns a route, but returns empty Geometry (a Polyline with 0 parts)
routeParam.OutputLine = TrueShape
Observation:  RouteResult returns a route, with a Polyline geometry. Polyline geometry contains M values
routeParam.OutputLine = TrueShapeWithMeasure
Observation: RouteResult returns a route, with a Polyline geometry. Polyline geometry contains M values.
My confusion here is:
- Does OutputLine.Default not solve for routing?
- OutputLine.Straight was suppose to return straight lines between stops, but the observation shows an empty geometry
- OutputLine.TrueShape and TrueShapeWithMeasure shows the same result (both has M values), should that be the case?
Further testing:
routeParameter.OutputGeometryPrecision = 0 / 10 / 1000;
routeParameter.OutputGeometryPrecisionUnit = LinearUnits.Meters
The above configuration returns the same geometry result for different OutGeometryPrecision values. I was expecting higher precision values to lower the number of points/line segments in the returned Geometry. Should that be the case?
Thanks in advance!
AsserSwelam1
Hi Lina,
Thanks for letting us know, try to go ahead and use the latest version 10.2.5 all OutputLine parameters works as expected, except Default value that is an issue we aware of.
Update: I apologize for the misunderstanding I thought you was talking about Online Routing, I tried LocalRouting as you mentioned and I am seeing the same behavior you described even on 10.2.5. We will work on fixing this issues.
Asser
AsserSwelam1
Hi Lina,
Asser
