lftgly
IGeocodingProperties AddStandardizeStringToMatchFields System.NotImplementedException
Discussion created by lftgly on Oct 5, 2010
Latest reply on Oct 19, 2010 by lftgly
I'm updating code to create Locators in ArcGIS 10, which works fine in ArcGIS 9.3.1 with the "US Streets with Zone" Locator Style.
Using the new "US Address - Dual Ranges" Locator Style, when I set the IGeocodingProperties
all work fine, consistent with Arc9, except when I set
.AddStandardizeStringToMatchFields to True, I get a runtime error:  System.NotImplementedException, "The method or operation is not implemented."
Developer Help does not indicate any changes in AddStandardizeStringToMatchFields
System.NotImplementedException was caught
  Message=The method or operation is not implemented.
  Source=ESRI.ArcGIS.Location
  StackTrace:
       at ESRI.ArcGIS.Location.IGeocodingProperties.set_AddStandardizeStringToMatchFields(Boolean bAddStandardizeStringToMatchFields)
       at ArcObjectsTools.GeocodingTools.CreateLocator_xTrakkerRoads(IWorkspace LocatorWorkspace, IFeatureClass ReferenceFeatureClass, String LocatorStyle, String LocatorName, GeocodeRangeType GCType, Boolean RebuildIfExists) in C:\src_tfs\Common\V32\Source\ArcObjectsTools\GeocodingTools.vb:line 230
  InnerException: (Nothing)
HResult -2147467263 Integer
The iReferenceDataTables.HasEnoughInfo = True
Any suggestions?
Thanks-
Outcomes
