ERROR 010092: Invalid output extent.
5013
03-29-2015 07:27 AM
xinglee1
I used ITransformationOp.Clip method, it's ok for the first 2 times, but the "ERROR 010092: Invalid output extent." began to occur from the 3rd time. So strange problems! Why? Thanks!
NahedTaha_Hassan_Zeini
Cause: the extent specified, either in the environment or as a parameter, is invalid for the output that is to be created.
Solution: Specify a valid extent for the output. If unsure what to use, set the Output extent in the Environment to Default.
xinglee1
Thanks Nahed! I saw that solution on the website. But May be it is not the end result. My code is as following.
public IRaster RasterClip (IRasterLayer pRasterLayer, IEnvelope pExtent)
            IRaster pRaster = pRasterLayer.Raster;
            IRasterProps pProps = pRaster as IRasterProps;
            object cellSizeProvider = pProps.MeanCellSize().X;
            IGeoDataset pInputDataset = pRaster as IGeoDataset;
           IGeoDataset pOutputDataset = pTransformionOp.Clip(pInputDataset, pExtent);
           IRaster clipRaster;
           clipRaster = pOutputDataset as IRaster;
