Operations Dashboard - Use of NOAA Storm Reports in List Widget
4178
03-26-2015 09:12 AM
KellyGrote
I have an Operations Dashboard with NOAA Storm reports. I am trying to start a list widget for Tornado reports. When I configure the widget, everything shows up properly in the preview, however in the list widget itself nothing shows up. Any ideas?
Tags (1)
ChristopherOlsen
Occasional Contributor III
Hi Kelly,
Which report are you using?  I just created a quick dashboard using the Category 4 storms and there's one in the Pacific now.  I did a list widget with some of the storm surge info (below).  Which layers are you using?
Chris
KellyGrote
I was trying  to create a list of tornado reports. I wasn't able to do it with wind or hail reports either. I tried the NOAA stream gauges and that worked.
ChristopherOlsen
Ok, I ended up playing with this a little more and used the ESRI live maps that are hooked up to the NOAA feeds and created a dashboard using those in my Operations Dashboard
Their live map is here: Severe Weather Disaster Map & Satellite Images | Esri Disaster Map
