phodkinson
exportPDF type mismatch
Discussion created by phodkinson on Sep 22, 2010
I'm stuck and confused!!!
I've got some code that works perfectly in vba in ArcMap 9.3.1.
However, when i put exactly the same code into a dll using vb6 i get a "Type Mismatch" error.
The code in question is:
Dim pExporter as IExport
Set pExporter = New ExportPDF - this line is where the error occurs.
I've referenced the ESRI Output Object Lib both in ArcMap and VB6.
I hope you can help
Cheers
Paul
Outcomes
