Is there a way to add NULL as a coded value in a domain?
4123
03-24-2015 12:19 PM
JoanSteinbacher
New Contributor III
I have several coded value domains set up in my geodatabase.  I want to add the value NULL as a Code with the Description "blank".  So if the attribute's value is <Null> it will display the string "blank".  Is this do-able?
StevenGraf1
Occasional Contributor III
I'm thinking the only way you could achieve this affect is if you set the default value to NULL.  You could set it to whatever you wanted actually to get the desired affect.
I don't think it is possible to have the <Null> value (value that displays when an attribute is left blank) set as a domain.  I tried setting it as a domain and it wasn't working.
Hope this helps
Steven
