Here's the answer to a question I never got around to asking three days ago (no, I'm not looking for points - I just hope it saves someone else hours of fruitless searching).
I am writing an Add-In that creates featureclasses that I want to add symbology to before they are added to ArcMap. I created a template layer in an ArcMap session that provides the proper symbology then saved it out to a layerfile. The idea is to deploy the layerfile along with the add-in. A solution cobbled together from various sources (thanks to those who contributed, unfortunately I've lost the cites...)
1. In Visual Studio - create a new folder under your add-in project folder called (in this instance) "Layerfiles"
2. Copy / paste the template layerfile into the new folder
4. Set the saved layerfiles properties: Build Action = Content, Copy to Output Directory = Copy Always
3. Add method to project
private void AddSavedLayerFileToMap(string folderName, string layerName, IFeatureClass gpsFClass, string aliasName)
try
//... Get map from current MxDocument
IMap pMap = pMxDoc.ActiveView.FocusMap;
//... Get the path to the layerfile
string codeBase = Assembly.GetExecutingAssembly().CodeBase;
UriBuilder uri = new UriBuilder(codeBase);
string AsmPath = System.IO.Path.GetDirectoryName(Uri.UnescapeDataString(uri.Path));
string layerFilePath = System.IO.Path.Combine(AsmPath, folderName + "\\" + layerName);
//... Create the layer to add to ArcMap
ILayerFile layerFile = new LayerFileClass();
layerFile.New(layerFilePath);
ILayer pSymbolLayer = layerFile.Layer;
IFeatureLayer pSymFLayer = (IFeatureLayer)pSymbolLayer;
pSymFLayer.FeatureClass = gpsFClass;
pSymbolLayer.Name = aliasName;
pMap.AddLayer(pSymFLayer);
catch (Exception ex)
MessageBox.Show(ex.Message);
The values of the parameters:
foldername - name you gave to the folder you added to your project folder in Visual Studio
layername - name of the template layerfile you added to the above folder
featureclass - the featureclass you want to add to ArcMap symbolized with the layerfile template
aliasName - a friendly name to call the layer once its added to the TOC in ArcMap
