AnsweredAssumed Answered
How to add feature attribute value
Question asked by KK2014 on Mar 20, 2015
Latest reply on Mar 23, 2015 by KK2014
I want to create o point feature and add string value to string attribute (ex:"description") in offline status and then sync to server.In my example I can create point feature and I give value to "description" attribute and then I give parameter in addFeature( ).In online mode my new point feature geometry created but my "description" attribute value is empty.How can I record my attribute value(ex:"Hi").?My code is below:
Thanks.
// Copyright 2014 ESRI
// All rights reserved under the copyright laws of the United States
// and applicable international laws, treaties, and conventions.
// You may freely redistribute and use this sample code, with or
// without modification, provided you include the original copyright
// notice and use restrictions.
// See the Sample code usage restrictions document for further information.
import QtQuick 2.2
import QtQuick.Controls 1.2
import ArcGIS.Runtime 10.3
import ArcGIS.Extras 1.0
ApplicationWindow {
    width: 800
    height: 600
    title: "OfflineTest"
     property double scaleFactor: System.displayScaleFactor
     property int fontSize: 15 * scaleFactor
     property bool isOnline: true
     property string featuresUrl: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Sync/WildfireSync/FeatureServer"
     property string gdbPath: "~/ArcGIS/Runtime/Data/Test/offlineSample.geodatabase"
     property var selectedFeatureId: null
     Envelope {
         xMin: -13643665.582273144
         yMin: 4533030.152110769
         xMax: -13618899.985108782
         yMax: 4554203.2089457335
     Map {
         anchors {
             left: parent.left
             top: parent.top
             right: parent.right
             bottom: msgRow.top
        extent: sfExtent
         ArcGISTiledMapServiceLayer
              url: "http://services.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"
         FeatureLayer {
             featureTable: featureServiceTable
             Component.onCompleted: {
                 renderer = onlineRenderer
         FeatureLayer {
             featureTable: GeodatabaseFeatureTable {
                 geodatabase: gdb.valid ? gdb : null
                 featureServiceLayerId: 0
             selectionColor: "cyan"
         onMouseClicked: {
             var featureJson = {
                             geometry: {
                             x: mouse.mapX,
                             y: mouse.mapY,
                             spatialReference: mouse.mapPoint.spatialReference
                                   attributes:
                                       description: "Hi"
                               var feature = offLineLayer.featureTable.addFeature(featureJson);
                                syncButton.enabled = true;
                                statusText.text = "Tap on Sync to update the Feature Service with the edits";
     SimpleRenderer {
         symbol: SimpleMarkerSymbol {
             style: Enums.SimpleMarkerSymbolStyleCircle
             color: "red"
     GeodatabaseFeatureServiceTable {
         url: featuresUrl + "/0"
     ServiceInfoTask {
         url: featuresUrl
         onFeatureServiceInfoStatusChanged: {
             if (featureServiceInfoStatus === ServiceInfoTask.FeatureServiceInfoComplete) {
                 statusText.text = "Service info received";
                 generateButton.enabled = true;
             } else if (featureServiceInfoStatus === ServiceInfoTask.featureServiceInfoError) {
                 statusText.text = "Error:" + errorString;
                 generateButton.enabled = false;
                 cancelButton.text = "Start Over";
     Feature {
     Point {
         spatialReference: mainMap.spatialReference
     Rectangle {
         anchors {
             fill: controlsColumn
             margins: -10 * scaleFactor
         color: "lightgrey"
         radius: 5 * scaleFactor
         border.color: "black"
         opacity: 0.77
     Column {
         anchors {
             left: parent.left
             top: parent.top
             margins: 20 * scaleFactor
         spacing: 7
         Button {
             text: "Generate Geodatabase"
             enabled: false
             onClicked: {
                 generateGeodatabaseParameters.initialize(serviceInfoTask.featureServiceInfo);
                 generateGeodatabaseParameters.extent = mainMap.extent;
                 generateGeodatabaseParameters.returnAttachments = true;
                 statusText.text = "Starting generate geodatabase task";
                 geodatabaseSyncTask.generateGeodatabase(generateGeodatabaseParameters, gdbPath);
                 busyIndicator.visible = true;
         Button {
             text: "Sync"
             width: generateButton.width
             enabled: false
             onClicked: {
                 enabled = false;
                 geodatabaseSyncTask.syncGeodatabase(gdb.syncGeodatabaseParameters, gdb);
                 statusText.text = "Starting sync task";
         Button {
             text: "Cancel"
             enabled: false
             onClicked: {
                 geodatabaseSyncTask.cancelJob(syncStatusInfo);
                 enabled = false;
                 text = "Cancel";
         Row {
             spacing: 10
             Text {
                 text: appWindow.isOnline ? "  Online " : "  Offline "
                 color: "black"
             Switch {
                checked: appWindow.isOnline
                 enabled: false
                 onCheckedChanged: {
                     appWindow.isOnline = checked;
                     if (checked === true && Enums.GenerateStatusCompleted)
                         statusText.text = "Switch to Offline Mode to continue editing.";
                     else if (checked === false && Enums.GenerateStatusCompleted)
                         statusText.text = "Select a feature.";
     Geodatabase {
         path: geodatabaseSyncTask.geodatabasePath
         onValidChanged: {
             if (valid) {
                 var gdbtables = gdb.geodatabaseFeatureTables;
                 for(var i in gdbtables) {
                     console.log (gdbtables[i].featureServiceLayerName);
     GeodatabaseSyncStatusInfo {
     GeodatabaseSyncTask {
         url: featuresUrl
         onGenerateStatusChanged: {
             statusText.text = generateStatus;
             if (generateStatus === GeodatabaseSyncTask.GenerateComplete) {
                 statusText.text = geodatabasePath;
                 cancelButton.enabled = false;
                 isOnline = false;
                 busyIndicator.visible = false;
             } else if (generateStatus === GeodatabaseSyncTask.GenerateError) {
                 statusText.text = "Error: " + generateGeodatabaseError.message + " Code= "  + generateGeodatabaseError.code.toString() + " "  + generateGeodatabaseError.details;
         onGeodatabaseSyncStatusInfoChanged: {
             if (geodatabaseSyncStatusInfo.status === Enums.GeodatabaseStatusUploadingDelta) {
                 var deltaProgress = geodatabaseSyncStatusInfo.deltaUploadProgress/1000;
                 var deltaSize = geodatabaseSyncStatusInfo.deltaSize/1000;
                 statusText.text = geodatabaseSyncStatusInfo.statusString + " " + String(deltaProgress) + " of " + String(deltaSize) + " KBs...";
             } else
                 statusText.text = geodatabaseSyncStatusInfo.statusString + " " + geodatabaseSyncStatusInfo.lastUpdatedTime.toString() + " " + geodatabaseSyncStatusInfo.jobId.toString();
             if (geodatabaseSyncStatusInfo.status !== GeodatabaseSyncStatusInfo.Cancelled)
                 cancelButton.enabled = true;
             syncStatusInfo.json = geodatabaseSyncStatusInfo.json;
         onSyncStatusChanged: {
             featureServiceTable.applyFeatureEdits();
             featureServiceTable.refreshFeatures();
             if (syncStatus === GeodatabaseSyncTask.SyncComplete) {
                 syncButton.enabled = false;
                 statusText.text = "Sync completed."
                 switchToggle.enabled = true;
                 var errorString = "";
                 for (var j = 0; j < syncErrors.featureEditErrors.length; j++) {
                     var error = syncErrors.featureEditErrors[j];
                     errorString += "\nLayer Id: " + error.layerId + "\nObject Id: " + error.objectId + "\nGlobal Id: " + error.globalId + "\nEdit operation: " + error.editOperationString + "\nError: " + error.error.description;
             if (syncStatus === GeodatabaseSyncTask.SyncError)
                 statusText.text = "Error: " + syncGeodatabaseError.message + " Code= "  + syncGeodatabaseError.code.toString() + " "  + syncGeodatabaseError.details;
     GenerateGeodatabaseParameters {
     Rectangle {
         anchors {
             fill: msgRow
             leftMargin: -10 * scaleFactor
         color: "lightgrey"
         opacity: 0.77
     Row {
         anchors {
             bottom: parent.bottom
             left: parent.left
             leftMargin: 10 * scaleFactor
             right: parent.right
         spacing: 10 * scaleFactor
         BusyIndicator {
             anchors.verticalCenter: parent.verticalCenter
             enabled: false
             visible: enabled
             height: (parent.height * 0.5) * scaleFactor
             width: height * scaleFactor
         Text {
             anchors.bottom: parent.bottom
             width: parent.width
             wrapMode: Text.WordWrap
             font.pixelSize: fontSize
     Rectangle {
         anchors.fill: parent
         color: "transparent"
         border {
             width: 0.5 * scaleFactor
             color: "black"
         statusText.text = "Getting service info";
         serviceInfoTask.fetchFeatureServiceInfo();
Outcomes
