Need help with create fishnet tool
3720
03-18-2015 09:43 AM
RobGordon
Hi, I am using a polygon fishnet to divide a county into 2km tetrads and I can do that fine but the tetrads do not line up with the gridlines on an OS map. I am using British National Grid projected co-ordinates. Should I be using a different one? or something else?
DarrenWiens2
MVP Honored Contributor
Your OS map (not familiar with the term) should provide you with some way to reference the coordinate system, as well as, hopefully, some coordinates to locate your grid. You can shift the grid back and forth using the origin coordinate parameters.
RobGordon
Thank you, that helps allot. The OS map stands for Ordinance Survey (UK mapping company).
