Robert,
I do have a few other questions (3) about my complete code for this project and was wondering if you wouldn't mind a little further guidance.
One:
I have a home button command that I'm trying to get to clear out the results from the results div tag. Here is what I have that doesn't seem to work with this particular application. It gives me an error finding the (results.rows). Any ideas how to clear out this data?
Here is my goHome.js
Resets the Map to its initial state with no routes selected and accordian pane back to default
function goHome(){
// Acitivates the Legend Accordian Tab
var container = dijit.byId("container");
container.selectChild("legendPane", true);
// This will remove old values in Routes Within 1/4 Mile Div Tag
var results = document.getElementById("results");
var rowCount = results.rows.length;
for (var x=rowCount-1; x>0; x--)
results.deleteRow(x);
// Removes Any simpleLineSymbols and Any simplePointSymbols
map.graphics.clear();
// Closes any open infoWindows
map.infoWindow.hide();
// Zoom to Map Extent
map.setExtent(mapExtent);
// Clears any address entered into Address Search Box
document.getElementById("search_input").value="";
TWO:
When creating my busRoutes layer, I don't want the map to allow users to click anywhere and it say (No Information). I also tried to use the on mouse-over for this layer and can't seem to get it to work. Any ideas on this one.
Creating the Template for Bus Route
busRouteContent = ("Name", "<tr><td><a
href='${TRAN_GD_PDF}'
target='_blank'>${NAME}</a></tr></td>");
busRouteTemplate = new esri.InfoTemplate;
busRouteTemplate.setContent(busRouteContent);
busRouteTemplate.setTitle("Bus
Route: ${ROUTE}");
busRoutes = new ArcGISDynamicMapServiceLayer("http://gis.rtcsnv.com/arcgis/rest/services/Maps/PROD_ADA_CERT/MapServer",
{id:"Routes"});
busRoutes.setInfoTemplates({
2: { infoTemplate: busRouteTemplate
busRoutes.setVisibleLayers([2]);
busRoutes.on("mouse-over", function()
map.setMapCursor("pointer");
busRoutes.on("mouse-out", function()
map.setMapCursor("default");
THREE:
In my Legend list this dynamic map service layers shows up using the application name and then its layer name. How can I remove the application part from the layer name. It currently shows up as: PROD_ADA_CERT RTC Bus Routes. I only want it to say RTC Bus Routes.
Solved! Go to Solution.
John,
One. The simplest way to clear the results div is to use a line like this
dojo.byId("results").innerHTML = '';
Two. As the layer is added as a dynamic map service layer and not a featurelayer you do not get mouse events like mouse over and mouse out. The click event actually launches a querytask under the hood of the API to see if they have clicked on your features.
Three. The easiest way if to add this to the css
.esriLegendLayerLabel { display: none; }
John,
Robert,
One: Perfect thank you.
Two: I removed the on.mouse events as they are no longer needed, Thank you.
Three: When I added this to my css it removed the RTC Bus Routes label portion and left the Application name: PROD_ADA_CERT instead. I'm not quite sure how to fix this as I only want the layer name (RTC Bus Routes). Is there a way for me to manually name it somehow?
Also, is there a way to remove the (No Information Available) popup when the user clicks around on the map? I have the measurement tool added to this application and when a user is measuring distance to walk to a bus stop this popup (No Information Available) pops up every time they click on the map.
Thank you again for the continued help. Your help is greatly appreciated.
John,
Three. Not that I am aware of.
Measure widget. When you activate the measure widget you need to use
map.setInfoWindowOnClick(false);
and when the measure widget is done turn it back on
map.setInfoWindowOnClick(true);
Robert,
Regarding the measurement widget. I simply have the following code below. I'm not sure where I would go about adding the code you supplied above. Again, thanks so much
var measurement = new Measurement({
map: map
}, dom.byId("measurementDiv"));
measurement.startup();
John,
In that case it is a little more:
var measurement = new Measurement({ map: map }, dom.byId("measurementDiv")); aspect.after(measurement, 'setTool', lang.hitch(this, function() { if (measurement.activeTool) { this.map.setInfoWindowOnClick(false); } else { this.map.setInfoWindowOnClick(true); } })); measurement.startup();
and of course you will need to require dojo/aspect
NEVERMIND, FIXED IT.
Had to add the "dojo/_base/lang", lang as well. Duh!!!!!!!!!!!!
Robert,
Didn't want to bug you but I added this to my code and it's not working out for me, tried for most of the day now to figure it out with no luck. Also, when I added this I lost some functionality that I have with Layers that I have a checkbox associated with. I did add the "dojo/aspect", aspect as well.
Also, the Measurement tool allows me to select all of the values and none of them actually work.
If user wants to see Paratransit Service Area this checks the checkbox to see if they turn it on or off
document.getElementById("checkBox0").onclick = function() {
if (this.checked) {
paraSvcArea.show();
else {
paraSvcArea.hide();
// If user wants to see Flexible Demand Response (FDR) Service Area this checks the checkbox to see if they turn it on or off
document.getElementById("checkBox1").onclick = function() {
if (this.checked) {
fdrSvcArea.show();
else {
fdrSvcArea.hide();
// If user wants to see Silverstar Routes this checks the checkbox to see if they turn it on or off
document.getElementById("checkBox2").onclick = function() {
if (this.checked) {
silverstar.show();
else {
silverstar.hide();
John,
Sorry I forgot about that.
Robert,
No worries at all you have been beyond helpful. I've got to start a new discussion soon on a few other questions that I have that perhaps I'll be able to once again thank you.
Thanks again for all the help, it's greatly appreciated. Have a great day.
