Encryption
2486
03-18-2015 10:56 AM
joshwilson2
Hi,so I am supposed to encrypt a text file chosen by a user at the moment I have completed most of it (offset factor/shift), I have got each separate character from the text file and put it into a list and converted it into ASCII, I am wondering how you are meant to change the ASCII number 32(space) into an actual space to separate the list and only them. Then i will need to create a string based on this and save it onto the user's computer and i am not too sure how to do this either.
Any help/advice will be appreciated
Thanks very much!
Here is the code:
import random
#=============================================Main Menu=============================================
print("Hi, Welcome to Text Encyrption")
print("This program will encrypt or decrypt a text file chosen by you.")
print('Make a choice')
print('1. Encrypt Message')
print('2. Decrypt Message ')
print('3. Exit program ')
print()
#the user only has 3 choices
menu_choice = 0
#menu_choice cannot = 3
while menu_choice != 3:
    menu_choice = int(input("Choose an option (1-3): "))
    #=====================================Encryption=======================================================
    if menu_choice == 1:
        print("ENCRYPTING MESSAGE")
        print("For this task the file is Text File1.txt")
        text_file = input(str("Enter the file you want to be Encyrpted"))
        #this will find the text file the user has inputter
        apple = open(text_file,"r")
        #this puts the text file so it can only be read
        apple =(apple.read())
        print(apple)
        n = 0
        number = []
        texting = []
        #================================Offset Factor===================================================
        #while n is less than 8
        while n<8:
            #it will convert a random number between 33 and 126 into ascii
            random_number = chr(random.randint(33, 126))
            print(random_number)
            #every time n + 1
            #one turn out of 8
            n = n + 1
            #the number is put into ascii
            characters = ord(random_number)
            #it is put into the number list
            number.append(characters)
        print(number)
        #this rounds each of the eight integers in number and divides by 8 and takes away 3
        offset_number = round((number[0]+number[1]+number[2]+number[3]+number[4]+number[5]+number[7])/8)-32
        #this prints the offset factor
        print(offset_number)
        #=============================Task 5=====================================================================
        newString = []
        #this is the only part of ascii allowed
        validLetters = "#$%&'()*+,-./:;<=>?@[\]^_`{|}~""#$%&'()*+,-./0123456789:;<=> @ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghiklmnopqrstuvwxyz{|}~"
        space = [' ']
        new = []
        old = []
        x = 0
        #this splits the text file into singukar characters from 0 to 1
        chrsplit = [apple for i in range(0, len(apple),1)]
        #this puts into ascii every character
        ascii_conversion = [ord(a) for a in chrsplit]
        #this replaces each 32 in the list with a space
        ascii_conversion = [s.replace('32', ' ') for s in ascii_conversion]
        #this prints it
        print(ascii_conversion)
https://community.esri.com/people/curtvprice/blog/2014/09/25/posting-code-blocks-in-the-new-geonet
