How can the "description" of a geodatabase domain be exported?
3543
03-17-2015 04:38 PM
RandyKreuziger
Occasional Contributor III
When a domain is created there is a description that can be filled out along with the domain properties.  This is separate from the description of domain codes.  Is there anyway to deport or copy out the domain's description?  There are too many domains to highlight, copy and paste them out.  Thanks
Tags (1)
DarrenWiens2
MVP Honored Contributor
There appears to be neither a geoprocessing tool nor property of arcpy.da Domain class to get at the domain description. You could venture into ArcObjects for the answer, but I'd just copy and paste in that case.
ModyBuchbinder
Hi
Check this: ArcGIS Help 10.2 - Example: Resolving domain codes to description values using SQL
You can get the domains properties from the metadata tables.
There should be a way to get descriptions too. Then you just have to export.
Have fun
Mody
