I have an Isopach (float) Raster and a Slope (float) Raster which are clipped to the same extents. I want to extract Isopach Values for Slope Values greater than 10 degrees. How do I accomplish this task. Using Spatial Analyst I Sampled the data but have yet to interpolate those data points to accomplish the task because it is tedious to create the complex polygons for clipping boundary. I was hoping I could perform a simple Raster to Raster query. I am a novice using VB Script and have never used python. Using raster calculator (VB Script) I was able to create a true false raster (1,0) that allowed me to view the extents of the Isopach along those areas but I want to retain the Isopach values. If this can be accomplished using raster calculator please reply with code. Thanks! Unfortunately, I cannot provide sample data it is proprietary.
*I found an acceptable workaround. Using ArcScan I created polygon features of the Slope Raster >10°. I then clipped the Isopach to the newly created boundaries. Still if anyone has any suggestions about how to perform this task based on raster to raster queries please reply*
