AnsweredAssumed Answered
Problem with Geodatabase Query code
Question asked by ssiddiqui on Mar 16, 2015
  Hi ,
I am new in Android Development so i am not able to figure out the problem,
trying to get the result on singletab using offline geodatabase. Following are the code
Its not returning the result and control is not going inside the onCallback method.
Please help me in resolving this .
@Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        // create the path to local tpk
        landDataFile = Environment.getExternalStorageDirectory();
        offlineDataSDCardDirName = this.getResources().getString(R.string.offline_dir);
        filename = this.getResources().getString(R.string.local_tpk);
        fileNameGeoDatabase = this.getResources().getString(R.string.local_geodatabase);
        // create the url
        String basemap = landDataFile + File.separator + offlineDataSDCardDirName + File.separator + filename;
        String geodatabasepath = landDataFile + File.separator + offlineDataSDCardDirName + File.separator + fileNameGeoDatabase;
        // for accessing the featurelayer using geodatabase
        try {
            geodatabase = new Geodatabase(geodatabasepath);
        } catch (FileNotFoundException e) {
            e.printStackTrace();
        geodatabaseFeatureTable = geodatabase.getGeodatabaseFeatureTableByLayerId(1);
        // Create feature layer and add the map into it.
        featureLayer = new FeatureLayer(geodatabaseFeatureTable);
       // featureLayer.getSelectedFeatures();
        featureLayer.setSelectionColor(12828800);  // added for identity
        featureLayer.setSelectionColorWidth(30);    //added for identity
        // create the mapview
        mMapView = (MapView) findViewById(R.id.map);
        // create the local tpk
        localTiledLayer = new ArcGISLocalTiledLayer(basemap);
        // add the layer
        mMapView.addLayer(localTiledLayer);
        mMapView.addLayer(featureLayer);
        Envelope env = new Envelope(398646.635989773, 2941161.63084675, 399056.211808925, 2941234.25911701);
        mMapView.setExtent(env);
        // enable panning over date line
        mMapView.enableWrapAround(true);
        // set Esri logo
        mMapView.setEsriLogoVisible(false);
        mMapView.setOnStatusChangedListener(new OnStatusChangedListener() {
            public void onStatusChanged(Object source, STATUS status) {
                // Check to see if map has successfully loaded
                if ((source == mMapView) && (status == STATUS.INITIALIZED)) {
                    // Set the flag to true
                    mIsMapLoaded = true;
        mMapView.setOnSingleTapListener(new OnSingleTapListener() {
            @Override
            public void onSingleTap(float x, float y) {
              //  geoDataBaseQuery();
                // convert event into screen click
                featureLayer.clearSelection();
                pointClicked = mMapView.toMapPoint(x, y);
                QueryParameters q = new QueryParameters();
                // optional
                q.setWhere("1=1");
                q.setOutSpatialReference(mMapView.getSpatialReference());
                q.setReturnGeometry(true);
                q.setSpatialRelationship(SpatialRelationship.INTERSECTS);
                q.setGeometry(pointClicked);
                q.setInSpatialReference(mMapView.getSpatialReference());
           //    q.setSpatialRelationship(SpatialRelationship.INTERSECTS);
           //     featureLayer.selectFeatures(q,SelectionMode.NEW,callback);
                featureLayer.selectFeatures(q,SelectionMode.NEW, new CallbackListener<FeatureResult>() {
                    @Override
                    public void onError(Throwable ex) {
                        // Highlight errors to the user.
                        showToast("Error querying FeatureServiceTable");
                    @Override
                    public void onCallback(FeatureResult objs) {
                        // If there are no query results, inform user.
                        if (objs.featureCount() < 1) {
                            showToast("No results");
                            return;
                        else {
                            // Report number of results to user.
                            showToast("Found " + objs.featureCount() + " features.");
                            // Iterate the results and select each feature.
                            for (Object objFeature : objs) {
                                Feature feature = (Feature) objFeature;
                                featureLayer.selectFeature(feature.getId());
Outcomes
