Making the app responsive to location change
3805
03-14-2015 02:12 AM
HaniDraidi
Occasional Contributor II
I am developing an app that finds my location using location services, when my location is defined, it is represented on the map by point. How can I make the map responsive to the change in my location, such that the map extent keeps my location in the center of the map, and when I rotate the device (change the device’s orientation), the map is rotated as well.
Any help is appreciated,
Hani
omega_cancer
I this LocationDisplayManager keeps track of this as you said your are using it already.
mMapView.setRotationAngle(); function accepts degree as double.
To get the degree consult following sources:
1.
magnetometer - Android Compass Bearing - Stack Overflow Read prashant​ answer.
2.
Mark Thorogood
at How to get Android compass reading? - Stack Overflow
3. Android Compass Code Example
4. https://www.codeofaninja.com/2013/08/android-compass-code-example.html
5. Coding for Android: Using orientation sensors: Simple Compass sample
Hope this will help
HaniDraidi
Thank you for the helpful resources Abdul Razzaq
ShellyGill1
Sounds like you might want to use LocationDisplayManager.setAutoPanMode(AutoPanMode.COMPASS) - "Centers the map at the current location, rotates the map to align with the direction in which the device is currently, and shows the location symbol." - LocationDisplayManager.AutoPanMode | ArcGIS Android 10.2.5 API .
