Seeking assistance on getting a freehand selection to push objects to a grid. Thanks,
<!DOCTYPE html>
<html>
<head>
<title>Title</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
<link rel="stylesheet" href="https://community.esri.com//code.jquery.com/ui/1.10.4/themes/smoothness/jquery-ui.css">
<script src="//code.jquery.com/jquery-1.10.2.js"></script>
<script src="//code.jquery.com/ui/1.10.4/jquery-ui.js"></script>
<style>
#mapDiv {
padding: 0;
margin: 0;
html, body {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
text-align: left;
body {
background-color: #FFF;
overflow: hidden;
font-family: "Trebuchet MS";
#bcMain {
width: 100%;
height: 100%;
#divRenderer {
position: absolute;
left: 27px;
bottom: 27px;
#cpBottom {
height: 100px;
#divGrid {
height: 100%;
.dgrid {
border: none;
.field-eqid {
width: 100px;
.field-datetime {
width: 160px;
.field-magnitude {
width: 60px;
.field-longitude {
width: 100px;
.field-latitude {
width: 100%;
.esriControlsBR{
display: none;
.esriPopup .esriPopupVisible { display: none;}
.esriPopupWrapper{ display: none;}
.tundra .dijitBorderContainer-dijitContentPane {
background-color: rgb(16, 100, 95);
height: 58px;
overflow: hidden;
.commandPanel {
height: 52px;
margin: 0px;
padding: 2px;
overflow: hidden;
position: absolute;
text-align: center;
vertical-align: middle;
.okIE .commandButton {
border-radius: 8px;
.commandButton {
width: 44px;
height: 44px;
text-align: center;
cursor: pointer;
.appTheme {
color: rgb(255, 255, 255);
.commandPanel table {
border-spacing: 0px;
.commandIcon {
width: 32px;
height: 32px;
margin-top: 6px;
#divBuff {
width: 200px;
max-height: 424px;
padding: 4px;
position: absolute;
display: none;
right: 7px;
top: 1%;
z-index: 999;
border-radius: 8px;
text-align: center;
border-color: 1px solid #121310;
text-align:left;
#appIcon {
float: left;
border: none;
border-style: none;
max-height: 95%;
margin: 5px;
.titleText {
height: 48px;
margin: 4px;
padding: 0px;
font-size: 175%;
word-wrap: break-word;
float: left;
#divLayers {
width: 421px;
height: 290px;
padding: 4px;
position: absolute;
display: none;
right: 7px;
top: 1%;
z-index: 999;
border-radius: 8px;
.layersBox {
width: 400px;
max-height: 270px;
padding: 4px;
position: absolute;
right: 7px;
top: 1%;
z-index: 999;
border-radius: 8px;
color: white;
text-align: left;
overflow-y: scroll;
overflow-x:hidden;
padding: 4px;
z-index: 40;
#divTableSearch {
width: 75%;
height: 175px;
padding: 4px;
position: absolute;
right: 50px;
display: none;
Bottom: 1%;
z-index: 999;
border-radius: 8px;
/* this line hides layers when out of scale for the inline TOC */
.agsjsTOCOutOfScale {
display: none
</style>
<script type="text/javascript">
var djConfig = {
parseOnLoad: true,
packages: [{
"name": "agsjs",
"location": "http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs"
</script>
<script>
$(document).ready(function(){
$("#Search").click(function(){
$("#divBuff").fadeToggle("fast");
$("#divTableSearch").fadeToggle("fast");
</script>
<script src="http://js.arcgis.com/3.10/"></script>
<script>
var toc;
require([
"esri/map",
"esri/layers/FeatureLayer",
"esri/tasks/query",
"esri/geometry/Circle",
"esri/graphic",
"esri/InfoTemplate",
"dojo/_base/connect",
"agsjs/dijit/TOC",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/dijit/Legend",
"dijit/registry",
"esri/dijit/Legend", "esri/tasks/GeometryService", "esri/tasks/BufferParameters", "dijit/form/Button",
"esri/geometry/Extent", "esri/graphicsUtils", "esri/toolbars/draw",
"dojo/dom-construct",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/renderers/SimpleRenderer",
"esri/config",
"esri/Color",
"dojo/dom",
"dojo/parser",
"dojo/store/Memory",
"dojo/data/ItemFileWriteStore",
"dgrid/OnDemandGrid",
"dojox/grid/EnhancedGrid",
"dojox/grid/enhanced/plugins/exporter/CSVWriter",
"dojox/grid/enhanced/plugins/Printer",
"dgrid/Selection",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/_base/declare",
"dojo/_base/array",
"dojo/on",
"dijit/form/ComboBox",
"dojo/domReady!"],
function(
Map,
FeatureLayer,
Query,
Circle,
Graphic,
InfoTemplate,
connect,TOC, ArcGISDynamicMapServiceLayer,Legend,
registry, Legend, GeometryService, BufferParameters,
Extent, Button, graphicsUtils, Draw, domConstruct,
SimpleMarkerSymbol,
SimpleLineSymbol,
SimpleFillSymbol,
SimpleRenderer,
esriConfig,
Color,
dom,
parser,
Memory,
ItemFileWriteStore,
Grid,
EnhancedGrid,
CSVWriter,
Printer,
Selection,
BorderContainer,
ContentPane,
declare,
array,
on
var map, gsvc, selectionToolbar, tb;
// Parse DOM nodes decorated with the data-dojo-type attribute
parser.parse();
console.log(registry.byId("zoomin"));
// Initialize the dgrid
var gridNF = new EnhancedGrid({
structure : [
{name: "name", field : "Name"},
{name: "requesttype", field : "Request Type"},
{name: "requestreceived", field : "Request Received"}
plugins: {
exporter: true,
printer: true
}, "divGrid");
gridNF.startup();
//Step: Specify the output fields
var outFieldsNF = ["objectid", "name", "requesttype", "requestreceived"];
// this should not be needed as nearly all query & select functions are performed on the client
// esriConfig.defaults.io.proxyUrl = "/proxy";
map = new Map("mapDiv", {
basemap: "gray",
center: [-96.000, 33.699],
zoom: 4,
slider: true
map.on("load", initSelectToolbar);
map.on("load", initToolbar);
var markerSymbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CIRCLE, 12,
new SimpleLineSymbol( SimpleLineSymbol.STYLE_NULL, new Color([100, 34, 250, 0.9]),1 ), new Color([255, 34, 25, 0.9])
var fieldsSelectionSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT,
new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5]));
var extentSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0]), 2), new Color([84, 84, 84, 0.5]));
// Note that an info template has been defined so when
//selected features are clicked a popup window will appear displaying the content defined in the info template.
var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/LocalGovernment/CitizenRequests/MapServer...",{
// infoTemplate: new InfoTemplate("Hospitals: ${NAME}", "${*}"),
outFields: ["objectid", "name", "requestreceived", "requesttype"],
mode: FeatureLayer.MODE_ONDEMAND
featureLayer.setSelectionSymbol(markerSymbol);
map.addLayer(featureLayer);
countyLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer", {
countyLayer.setVisibility(true);
//add the legend
map.on("layers-add-result", function (evt) {
var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
return {
layer: layer.layer,
title: layer.layer.name
if (layerInfo.length > 0) {
var legendDijit = new Legend({
map: map,
layerInfos: layerInfo
}, "legendDiv");
legendDijit.startup();
//add check boxes
arrayUtils.forEach(layerInfo, function (layer) {
var layerName = layer.title;
if (layerName == undefined) { layerName = "SSSI"; }
var checkBox = new CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible,
onChange: function (evt) {
var clayer = map.getLayer(this.value);
clayer.setVisibility(!clayer.visible);
this.checked = clayer.visible;
//add the check box and label to the TOC
domConstruct.place(checkBox.domNode, "toggle",
"after");
var checkLabel = domConstruct.create('label', {
'for': checkBox.name,
innerHTML: layerName
}, checkBox.domNode, "after");
domConstruct.place("<br/>", checkLabel,
"after");
// map.addLayer(countyLayer);
map.addLayers([ featureLayer, countyLayer]);
//Add Table of Contents
on(dom.byId("selectPolygonButton"), "click", function () {
selectionToolbar.activate(Draw.EXTENT);
on(dom.byId("selectCircleButton"), "click", function () {
selectionToolbar.activate(Draw.CIRCLE);
on(dom.byId("selectFreehandPolygonButton"), "click", function () {
selectionToolbar.activate(Draw.FREEHAND_POLYGON);
on(dom.byId("clearSelectionButton"), "click", function () {
featureLayer.clearSelection();
map.graphics.clear();
dom.byId("messages").innerHTML = "<a>No features selected</a>";
function initSelectToolbar(event) {
alert("initSelectToolbar ");
selectionToolbar = new Draw(event.map);
var selectQuery = new Query();
on(selectionToolbar, "DrawEnd", function (geometry) {
var promises = [];
var graphic = new Graphic(geometry, extentSymbol);
console.log(graphic);
map.graphics.add(graphic);
selectionToolbar.deactivate();
selectQuery.returnGeometry = false;
selectQuery.outFields = ["*"];
selectQuery.geometry = geometry;
if(featureLayer.visible){
promises.push(featureLayer.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW));
var allPromises = new All(promises);
allPromises.then(function (r) {
showselResults(r);
gsvc = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
function initToolbar(evtObj) {
alert("initToolbar ");
app.tb = new Draw(evtObj.map);
app.tb.on("draw-end", doBuffer);
// selection symbol used to draw the selected census block points within the buffer polygon
// map.addLayer(featureLayer);
// var circleSymb = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL,new SimpleLineSymbol(
// SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
// new Color([105, 105, 105]), 3 ), new Color([255, 255, 0, 0.25])
// var circle;
// var radius = parseInt(dom.byId("bufferDistance").value);
//when the map is clicked create a buffer around the click point of the specified distance.
// map.on("click", function(evt){
// circle = new Circle({
// center: evt.mapPoint,
// // geodesic: true,
// radius: radius,
// radiusUnit: "esriMiles"
// map.graphics.clear();
// map.infoWindow.show();
// var graphic = new Graphic(circle, circleSymb);
// map.graphics.add(graphic);
// var query = new Query();
// query.geometry = circle.getExtent();
// //use a fast bounding box query. will only go to the server if bounding box is outside of the visible map
// featureLayer.queryFeatures(query, selectInBuffer);
// function selectInBuffer(response){
// var feature;
// var features = response.features;
// var inBuffer = [];
//filter out features that are not actually in buffer, since we got all points in the buffer's bounding box
// for (var i = 0; i < features.length; i++) {
// feature = features;
// if(circle.contains(feature.geometry)){
// inBuffer.push(feature.attributes[featureLayer.objectIdField]);
// query.objectIds = inBuffer;
//use a fast objectIds selection query (should not need to go to the server)
// featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
// var totalFeatures = results.length;
// var r = "";
// r = "<b>The total Number of Nursing Homes within the Buffer <i>" + totalFeatures+ "</i>.</b>";
// dom.byId("messages").innerHTML = r;
// populateGrid(response);
//Step: Wire the layer's selection complete event
//FeatureLayer.on("selection-complete", populateGrid);
// Step: Perform the selection
//FeatureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW);
function showselResults(results) {
var rsltsMsg = "";
rsltsMsg = 'Total features selected: <b>[count]</b><br> ';
var rsltCnt = 0;
rsltsMsg += 'FeatureLayer 1: <b>' + results[rsltCnt].length.toString() + '</b><br>  ';
rsltCnt++;
var count = 0;
for (var i = 0; i < results.length; i++) {
count += results.length;
dom.byId("messages").innerHTML = rsltsMsg.replace('[count]', count);
function populateGrid(results) {
var gridData;
dataNF = array.map(results.features, function(feature) {
return {
// Step: Reference the attribute field values
"objectid" : feature.attributes[outFieldsNF[0]],
"name" : feature.attributes[outFieldsNF[1]],
"requesttype" : feature.attributes[outFieldsNF[2]],
"requestreceived" : feature.attributes[outFieldsNF[3]]
// Pass the data to the grid
var memStore = new ItemFileWriteStore({
data : {
identifier: 'OBJECTID',
items: dataNF
gridNF.setStore(memStore);
on(dojo.byId("exportAll"), "click", function () {
gridNF.exportGrid("csv", function(str){
alert(str);
on(dojo.byId("printAll"), "click", function () {
gridNF.printGrid({title: "Hospital List", cssFiles: []});
function doBuffer(evtObj) {
var geometry = evtObj.geometry,
map = app.map,
gsvc = app.gsvc;
switch (geometry.type) {
case "point":
var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1), new Color([0, 255, 0, 0.25]));
break;
case "polyline":
var symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([255, 0, 0]), 1);
break;
case "polygon":
var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NONE, new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]));
break;
var graphic = new Graphic(geometry, symbol);
//setup the buffer parameters
var params = new BufferParameters();
params.distances = [dom.byId("distance").value];
params.unit = GeometryService[dom.byId("unit").value];
if (geometry.type === "polygon") {
//if geometry is a polygon then simplify polygon. This will make the user drawn polygon topologically correct.
gsvc.simplify([geometry], function (geometries) {
params.geometries = geometries;
gsvc.buffer(params, showBuffer);
} else {
params.geometries = [geometry];
function showBuffer(bufferedGeometries) {
new Color([255, 0, 0, 0.65]), 2),
new Color([255, 0, 0, 0.35]));
arrayUtils.forEach(bufferedGeometries, function (geometry) {
app.map.graphics.add(graphic);
app.tb.deactivate();
app.map.showZoomSlider();
app = {
map: map,
tb: tb,
gsvc: gsvc
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;">
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:40px;">
<div id="appTitle" style= "vertical-align: middle; padding-left: 20px">
<span class="titleText" style="color:white;">Title</span>
<div id="commandPanel" class="commandPanel" style="right: 4px; top:4px;">
<table class="appTheme">
<tbody>
<tr>
<td class="commandPanelItem"><div id="Search" class="commandButton appTheme appThemeHover" title="Find" style="display: block; visibility: visible;"><img src="http://webhelp.esri.com/arcgisexplorer/1500/gpsicons/GPX_107_air_strip.png" class="commandIcon"></div></td>
</tr>
</tbody>
</table>
</div> <!-- ENd HEADER -->
</div>
</div>
<div id="mapDiv" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;">
<div id="divBuff" class="searchBox appTheme" style="right: 2px; top: 2px; bottom: 2px;">
<label for="searchBox_entry">Buffer Tools </label>
<span id="drop"><form name="FormSelection">
<!-- <select name="selection" onChange="selecteduser()"> -->
<select name="BufferSelection">
<option> Layer 1</option>
</select>
</form> </span>
<br/><br/>
<span id="messages"></span>
<br/>
<div><b>Feature Selection</b></div>
<button id="selectPolygonButton" data-dojo-type="dijit/form/Button">Polygon</button>
<button id="selectCircleButton" data-dojo-type="dijit/form/Button">Circle</button>
<button id="selectFreehandPolygonButton" data-dojo-type="dijit/form/Button">Freehand Polygon</button>
<button id="clearSelectionButton" data-dojo-type="dijit/form/Button">Clear Selection</button>
<br /><hr />
<button id="exportAll">Export all to CSV</button>
<button id="printAll">Print All</button>
</div> <!-- End BufferDiv -->
</div>
<div id="divLayers">
<div id="layersBox" class="layersBox appTheme" style="right: 2px; top: 2px; display: block;">
<div id="divLayersTitle">Toggle Visible Layers:</div>
</div>
</div> <!-- End divLayers -->
<div id="divTableSearch" align="center">
<div id="divGrid"style="height:110px;">
</div> <!-- End divGrid -->
</div> <!-- End divTableSearch -->
</div><!-- End Map Div -->
</div><!--Headline -->
</body>
</html>
