AnsweredAssumed Answered
Attachment photo info returned with ID task
Question asked by amarsden on Mar 10, 2015
see Find attachments using task in JavaScript API
But I've sort of moved on, so I thought I'd open a new thread.
So, (as every sentence has to start with "so" these days)
I am detecting if my layers have attachments on load with a call to the REST thingy, this is stored in an array, with the array index matching the LayerID
When I go through the records returned in the results dataset of an ID task, I check the layerID of returned record against this array and if it has attachments I then do stuff.
That's my first issue.  I used something like this
                 if (layerHasAttachments) {
                        objectId = results[i].feature.attributes.OBJECTID;
                        t = mapservice2 + "/" + results[i].layerId.toString();
                        featureLayer = new esri.layers.FeatureLayer(t, {
                            mode: esri.layers.FeatureLayer.MODE_ONDEMAND
                        //use queryAttachmentInfos to return into array the path of each attachment
                        featureLayer.queryAttachmentInfos(objectId, function (infos) {
                            if (infos.length > 0) {
                                for (index = 0; index < infos.length; ++index) {
                                    attachmentPath.push(infos[index].url)
                            console.debug(2);
                        console.debug(3);
However, the code carried on before the results came in -0 I get my debug 3, before my debug 2 - so I have issues then deciding if action is needed if a feature has an attachment. - So, first issue, how can I wait for the info from the "queryAttachmentInfos" before moving on?
I had to move on, so every feature in that is in the results dataset that is in a layer that is enabled for attachments has a button next to the result.  This opens a popup where I show the photos (currently we only have photos, so I haven't done the code to detect attachment type).  My code is
        imagePopupHTML = "<!DOCTYPE html><html xmlns='http://www.w3.org/1999/xhtml\'><head><title></title></head>'";
                console.debug(infos[index])
        for (index = 0; index < attachmentPath.length; ++index) {
            imagePopupHTML += "<a href='" + attachmentPath[index] + "'>"
            imagePopupHTML += "<img src='" + attachmentPath[index] + "' style='width:600px'></a></br>"
        imagePopupHTML += "<body></body></html>"
        OpenWindowThumb = window.open("", "thumb", "height=" + popY + ", width=" + popX + ",toolbar=no,scrollbars=yes,menubar=no,resizable=yes");
        OpenWindowThumb.document.getElementsByTagName('body')[0].innerHTML = 'Please Wait';
        OpenWindowThumb.focus()
        OpenWindowThumb.document.getElementsByTagName('body')[0].innerHTML = '';
        OpenWindowThumb.document.write(imagePopupHTML);
So I get the URL and fling it into an basic HTML page - not elegant, but I am pushed for time and needed to show people that field collected data from Collector can be seen in the office in our browser mapping.
If I use the raw URL for an image in Chrome, it detects the orientation.  IE doesn't.  So I am guessing that some metadata is stored with the image.  I have failed totally in getting it.  I tried a few add on chunks of code, but they didn't return what I was after.  So, that's the next question - Is it possible to query the server to get image rotation info (and other metadata)
Many thanks
ACM
Outcomes
