editor InfoTemplate not showing up
3648
03-09-2015 10:37 AM
RichardMoussopo
Occasional Contributor III
for some reason, when selecting a feature onEdit mode, the EditTemplate window is not showing up. I have it setup to custom fields as code below:
appEditor = {
        Edit: function (evt) {
            // alert(evt);
            if (evt === "Permit") {
                if (editorWidget) {
                    editorWidget.destroy();
                    editorWidget = null;
                var txtSewerPermit = new dijit.form.TextBox({
                    required: false,
                    promptMessage: "Add Sewer Permit",
                    style: "height:1.8em; width:260px;margin:2px; background-color:#ffd800"
                var txtWaterPermit = new dijit.form.TextBox({
                    required: false,
                    promptMessage: "Add Water Permit",
                var templateLayers = [permit];
                var eDiv = document.createElement("div");
                eDiv.id = "editDiv";
                document.getElementById('EditContent1').appendChild(eDiv);
                var eDivTools = document.createElement("div");
                eDivTools.id = "editDivTools";
                document.getElementById('EditContent1').appendChild(eDivTools);
                map.infoWindow.resize(400, 350);
                var editLayerPermit1 = [{
                    featureLayer: permit,
                    showDeleteButton: false,
                    fieldInfos: [
                       { 'fieldName': 'Date', 'label': '<table><tr><td style="width:260px;height: 1.8em; margin:2px">Date: </td></tr></table>' },
                        { 'fieldName': 'ADDRESS', 'label': '<table><tr><td style="width:260px;height: 1.8em; margin:2px">Address: </td></tr></table>' },
                        { 'fieldName': 'SewerPermit', 'label': 'Sewer Permit: ',   customField: txtSewerPermit },
                        { 'fieldName': 'WaterPermit', 'label': 'Water Permit: ', customField: txtWaterPermit },
                            'fieldName': 'SERVICE_ID', 'label': 'Add Permit: ', customField: "<br /><b> Sewer Permit</b>: <br />" +
                              "<div id='progressNumberSP' style='padding:2px; color:red'></div><input type='file' name='fileToUploadSP' id='fileToUploadSP' onclick='if(!getNoneTxt){this.disabled = true; return false}'   onchange='uploadFileSP(this.files[0]);' />" +
                              "<br /><br /><b>Water Permit</b>: <div id='progressNumberWP' style='padding:2px; color:red'></div><input type='file' name='fileToUploadWP' id='fileToUploadWP'   onchange='uploadFileWP(this.files[0]);' />"
                }]; // editLayers;
                var templatePicker = new esri.dijit.editing.TemplatePicker({
                    featureLayers: templateLayers,
                    rows: 'auto',
                    columns: 3
                }, 'editDiv');
                templatePicker.startup();
                var settings = {
                    map: map,
                    templatePicker: templatePicker,
                    layerInfos: editLayerPermit1, //editLayerSitePlan1
                    toolbarVisible: true,
                    enableUndoRedo: true
                var params = {
                    settings: settings
                editorWidget = new esri.dijit.editing.Editor(params, 'editDivTools');
                editorWidget.startup();
here is the error I get:
TypeError: undefined is not a function {stack: (...), message: "undefined is not a function"} "TypeError: undefined is not a function
    at v._createField (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:30:440)
    at h._hitchArgs (http://js.arcgis.com/3.10/init.js:173:204)
    at Object.h.forEach (http://js.arcgis.com/3.10/init.js:225:144)
    at v._createTable (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:28:56)
    at v._setCurrentLInfo (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:19:432)
    at v._showFeature (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:23:86)
    at v._updateSelection (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:20:101)
    at v.onLayerSelectionChange (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:10:321)
    at h.(anonymous function).g [as onSelectionComplete] (http://js.arcgis.com/3.10/init.js:239:390)
    rejected at a (http://js.arcgis.com/3.10/init.js:196:337)
    at k (http://js.arcgis.com/3.10/init.js:196:89)
    at f.then.b.then [as then] (http://js.arcgis.com/3.10/init.js:198:308)
    at S.selectFeatures (http://js.arcgis.com/3.10/js/esri/layers/FeatureLayer.js:38:212)
    at http://js.arcgis.com/3.10/js/esri/dijit/editing/SelectionHelper.js:5:469
    at Object.h.forEach (http://js.arcgis.com/3.10/init.js:225:179)
    at l.selectFeatures (http://js.arcgis.com/3.10/js/esri/dijit/editing/SelectionHelper.js:5:325)
    at l.selectFeaturesByGeometry (http://js.arcgis.com/3.10/js/esri/dijit/editing/SelectionHelper.js:7:214)
    at v._updateSelection (http://js.arcgis.com/3.10/js/esri/dijit/editing/Editor.js:39:519)
    at null.<anonymous> (http://js.arcgis.com/3.10/js/esri/dijit/editing/Editor.js:33:428)
Error
    at f.then.b.then [as then] (http://js.arcgis.com/3.10/init.js:198:253)
    at h.hitch (http://js.arcgis.com/3.10/init.js:174:23)
    at v._updateCurrentFeature (http://js.arcgis.com/3.10/js/esri/dijit/editing/Editor.js:17:126)"
RichardMoussopo
is it possible to set the infoTemplate on a dynamicMapServiceLayer as we do a FeatureLayer? I would like to avoid identfy as much as possible. it is the cause of my error as above.
like
  var infoTemplateUtilitiesheader = "FacilityID: <b>${Facility Identifier}</b> <br/><br/>";
    var infoTemplateUtilitiesBody = "${*}";
    var utilitiesLayer = new ArcGISDynamicMapServiceLayer("http://...", {
        infoTemplate: new InfoTemplate(infoTemplateUtilitiesheader, infoTemplateUtilitiesBody)
        //opacity: .20
RobertScheitlin__GISP
Richard,
  Sure look at the setInfoTemplates function on ArcGISDynamicMapServiceLayer.
ArcGISDynamicMapServiceLayer | API Reference | ArcGIS API for JavaScript
          var demographicsLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer");
          demographicsLayer.setInfoTemplates({
            0: { infoTemplate: popupTemplate }
