Good day
I have a road layer and a point layer representing villages. The points need to become villages.
with same tools (buffer, random points tool, etc) I have this so far:
Looks about right but..
-is it possible to have same random on the square width and length?
-is it possible to have the houses align to the roads?
So far i was looking at script by ET geo wizards “polygon_rotate_byFieldValues.cal”
'========================= 'polygon_rotate_byFieldValues.cal 'Author: Ianko Tchoukanski 'http://www.ian-ko.com '========================= Dim pPolygon As IPolygon dim pArea As IArea Dim pOrigin As IPoint Dim dAngle As Double Dim pTransform As ITransform2D Dim Pi as Double Dim sAngleField '======================= 'adjust the value below sAngleField = [Angle] '======================= Pi = 4 * Atn(1) If (Not IsNull([Shape])) Then Set pPolygon = [Shape] dAngle = sAngleField*Pi/180 If (Not pPolygon.IsEmpty) Then Set pArea = pPolygon Set pOrigin = pArea.Centroid Set pTransform = pPolygon pTransform.Rotate pOrigin, dAngle End If End If __esri_field_calculator_splitter__ pPolygon
looks promising but it is not working
Thank you and greetings Peter
