As I am trying to work on getting this problem done , I am using Mosaic Dataset for the whole state of New Mexico using our NAIP ...now the problem is that I could not get rid of the white "box". I tried to remove the raster of that area and then add the raster again and then build the seamline, footprints and then build the overviews....same problem....
Is there a way around to fix the problem ?
Just to clarify the issue, the individual NAIP images for the extent you show with the white box completely cover that extent, corrrect? Any chance one or more of the images have "No Data" in that extent? Also, is there overlap between the images?
Chris Donohue, GISP
Yes, When I added the rasters I did not do anything ....is there something I need to turn off or on on some of the raster(s) ?
I'm rusty on mosaicing, so don't have an answer at the moment.
If I had to make a guess, I'd say possibly the Method needs to be adjusted. Just a guess, though....
Understanding the mosaicking rules for a mosaic dataset
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Chris Donohue, GISP
Chris, Understand. Am in the same boat as you are....but learning as well....try to understand what's the workflow.....
Have a good day, Chris.
