AnsweredAssumed Answered
The error that we receive is “Fatal signal 6 (SIGABRT), code -6”.
Question asked by Lilya@123 on Mar 5, 2015
We are having an issue with the ArcGIS Runtime SDK (version 10.2.5) for Android, in particular when running on Android 5.0 - Lollipop (when
  running on a 4.4 device, the problem does not occur).  The error that we encounter when loading a map using ArcGISTiledMapServiceLayer().  We are
  using token authentication, so only a single parameter in the initialisation.  The error that we receive is “Fatal signal 6 (SIGABRT),
  code -6”.  We are confident that the issue is either with the Runtime SDK library or something with the configuration of the ArcGIS server.
  Have you encountered this error before, and how should we proceed to get around the issue?
Outcomes
