Create Enterprise Geodatabase failure: Failed to setup st_geometry type.Failed to create the ST_Geometry metadata tables during install.
4828
6
03-05-2015 08:02 AM
BrunoMendes
I'm trying to create an Enterprise Geodatabse in Oracle 11g hosted in an Exadata environment.
The message printed by the tool is: Failed to setup st_geometry type.Failed to create the ST_Geometry metadata tables during install.
The log generated is attached as sde_setup.log.
I've already checked the knowledgebade and based on this article I've run two sql queries:
  1. SELECT OWNER, NAME, TYPE FROM DBA_DEPENDENCIES WHERE REFERENCED_NAME  = 'ST_GEOMETRY' AND REFERENCED_TYPE  = 'TYPE' AND TYPE = 'TABLE';
  2. SELECT OWNER, TABLE_NAME, COLUMN_NAME FROM DBA_TAB_COLUMNS WHERE DATA_TYPE = 'ST_GEOMETRY'.
Both of them returns nothing.
MagalyC_
Hi !
Have you found the solution ? I have the same problem.
Thanks a lot.
BirajaNayak
As per article, query is as per below:
SELECT OWNER, NAME, TYPE FROM DBA_DEPENDENCIES WHERE REFERENCED_OWNER='MDSYS' AND REFERENCED_NA
ME = 'ST_GEOMETRY' AND REFERENCED_TYPE = 'TYPE' AND TYPE='TABLE';
Please run the above query as it is using "sys" login. This may help.
Biraja
MagalyC_
Hi, this query returns nothing.
With this query :
SELECT OWNER, NAME, TYPE, REFERENCED_NAME, REFERENCED_TYPE FROM DBA_DEPENDENCIES WHERE REFERENCED_NAME = 'ST_GEOMETRY';
I have this result (see attachement)
Thanks.
BirajaNayak
Please run the below query and let us know your result:
MagalyC_
This query return nothing.
zhenzhang1
I have the same problem,how to solve it?
thanks
