i cant add a shape file to the map
can any one tell me what is error here
it not display any error but also it dose not add file to the map
this is my code"
_addShapeFile: function (tool, toolbar, panelClass) {
var ShapeFileDiv = toolbar.createTool(tool, panelClass);
domStyle.set(ShapeFileDiv, {
"height": "100%",
"width": "100%"
//var newDiv1 = document.createElement("div");
//document.getElementById("newDiv1").appendChild(ShapeFileDiv);
////newDiv1.appendChild(ShapeFileDiv);
var file = document.createElement("INPUT");
file.setAttribute("type", "file");
var uploadForm = dojo.place("<form> Add shapefile as .zip file </form>", ShapeFileDiv);
domConstruct.place(file, uploadForm);
var ShapeFilebutton = domConstruct.create("button", {
innerHTML: "Add FIle ",
className: "button",
type: "button",
style: { color: "red" }
}, domConstruct.create("div", {
"class": "button11"
domConstruct.place(ShapeFilebutton, ShapeFileDiv);
on(ShapeFilebutton, "click", function () {
parser.parse();
map = maps;
var portalUrl = "http://www.arcgis.com";
esriConfig.defaults.io.proxyUrl = "/proxy/";
//1
// on(dom.byId("x"), "change", function (event) {
// var fileName = event.target.value.toLowerCase();
var fileName = file.value;
if (sniff("ie")) { //filename is full path in IE so extract the file name
var arr = fileName.split("\\");
fileName = arr[arr.length - 1];
if (fileName.indexOf(".zip") !== -1) {//is file a zip - if not notify user
generateFeatureCollection(fileName);
//2
else {
function generateFeatureCollection(fileName) {
var name = fileName.split(".");
//Chrome and IE add c:\fakepath to the value - we need to remove it
//See this link for more info: http://davidwalsh.name/fakepath
name = name[0].replace("c:\\fakepath\\", "");
//3
//Define the input params for generate see the rest doc for details
//http://www.arcgis.com/apidocs/rest/index.html?generate.html
var params = {
'name': name,
'targetSR': map.spatialReference,
'maxRecordCount': 1000,
'enforceInputFileSizeLimit': true,
'enforceOutputJsonSizeLimit': true
//generalize features for display Here we generalize at 1:40,000 which is approx 10 meters
//This should work well when using web mercator.
var extent = scaleUtils.getExtentForScale(map, 40000);
var resolution = extent.getWidth() / map.width;
params.generalize = true;
params.maxAllowableOffset = resolution;
params.reducePrecision = true;
params.numberOfDigitsAfterDecimal = 0;
var myContent = {
'filetype': 'shapefile',
'publishParameters': JSON.stringify(params),
'f': 'json',
'callback.html': 'textarea'
//use the rest generate operation to generate a feature collection from the zipped shapefile
request({
url: portalUrl + '/sharing/rest/content/features/generate',
content: myContent,
form: dom.byId('uploadForm'),
handleAs: 'json',
load: lang.hitch(this, function (response) {
if (response.error) {
errorHandler(response.error);
return;
var layerName = response.featureCollection.layers[0].layerDefinition.name;
addShapefileToMap(response.featureCollection);
error: lang.hitch(this, errorHandler)
function errorHandler(error) {
//dom.byId('upload-status').innerHTML =
//"<p style='color:red'>" + error.message + "</p>";
function addShapefileToMap(featureCollection) {
//add the shapefile to the map and zoom to the feature collection extent
//If you want to persist the feature collection when you reload browser you could store the collection in
//local storage by serializing the layer using featureLayer.toJson() see the 'Feature Collection in Local Storage' sample
//for an example of how to work with local storage.
var fullExtent;
var layers = [];
arrayUtils.forEach(featureCollection.layers, function (layer) {
var infoTemplate = new InfoTemplate("Details", "${*}");
var featureLayer = new FeatureLayer(layer, {
infoTemplate: infoTemplate
//associate the feature with the popup on click to enable highlight and zoom to
featureLayer.on('click', function (event) {
map.infoWindow.setFeatures([event.graphic]);
//change default symbol if desired. Comment this out and the layer will draw with the default symbology
changeRenderer(featureLayer);
fullExtent = fullExtent ?
fullExtent.union(featureLayer.fullExtent) : featureLayer.fullExtent;
layers.push(featureLayer);
map.addLayers(layers);
map.setExtent(fullExtent.expand(1.25), true);
//5
// dom.byId('upload-status').innerHTML = "";
function changeRenderer(layer) {
//change the default symbol for the feature collection for polygons and points
var symbol = null;
switch (layer.geometryType) {
case 'esriGeometryPoint':
symbol = new PictureMarkerSymbol({
'angle': 0,
'xoffset': 0,
'yoffset': 0,
'type': 'esriPMS',
'url': 'http://static.arcgis.com/images/Symbols/Shapes/BluePin1LargeB.png',
'contentType': 'image/png',
'width': 20,
'height': 20
break;
case 'esriGeometryPolygon':
symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([112, 112, 112]), 1), new Color([136, 136, 136, 0.25]));
break;
if (symbol) {
layer.setRenderer(new SimpleRenderer(symbol));
// deferred.resolve(true);
// } else {
// deferred.resolve(false);
//return deferred.promise;
Solved! Go to Solution.
Have you looked at this sample: Add shapefile | ArcGIS API for JavaScript
You can download the source as a zip file and extend it to meet your needs.
no one have idea??!!!
