SRTM Interpolation Trial Version
4049
6
02-27-2015 09:05 AM
YannickStachelscheid
Hey guys
I'm new to ArcGis and the general topic geo data.
I came to ArcGis because I need to interpolate the 90m SRTM data (Europe) and I found this post. I want to use the data later in a game I'm developing.
So I just downloaded the trial version of ArcGis and clicked a little bit through the Applications (ArcGlobe, ArcMap, ArcScene). But I can't find ArcGIS Spatial Analyst which was mentioned in the old post.
So is it possible to perform the SRTM interpolation with the trial version? If so, how can I do it?
Thanks for help and replies
Greetings from Germany
DanPatterson_Retired
If you go to the Customize menu, then select Extensions...if you have it, it can be toggled on.  Most of the functionality is in Arctoolbox (little red tool on the toolbar)
SteveLynch
What interpolation are you trying to do? Fill in voids or resample it to a finer resolution?
Voids have already been filled because I'm using data from Coverage map viewfinderpanoramas.org , so I want a finer resolution
SteveLynch
You could simply use the Resample (in Data Management) tool and choose bilinear interpolation.
Thank you for that tip I resampled data from 90m to 30m, but how can I save the resampled data as .hgt again?
from the help files on SRTM which means that you need to use arcobjects
Supported raster formats
So you will have to examine that documentation
Mission (SRTM)
The HGT format is used to store elevation data from the Shuttle Radar Topography Mission (SRTM). SRTM-3 and SRTM-1 v2 files can be displayed.
Single file—extension *.hgt
Read-only (Write—developer only
