Arc Python for Arc Hydro
4512
5
02-25-2015 03:40 PM
MarkBoucher
Occasional Contributor III
I'm interested in learning how to use Arc Python for Arc Hydro. Can anyone suggest a stream in GeoNet that might be good for that?
DanPatterson_Retired
Does ArcHydro have their own Python routines?
MarkBoucher
Not sure. I believe the tools can be called from Arc Python, but I'd like to see some Arc Hydro specific code so I can make an easier transition from Model Builder to Arc Python.
Just did a web search using Archydro and Python and there are a number of threads, including one with you in it, It appears that things are largely a shell around the spatial analyst tools.  In any event, you might want to do a search there, if there is nothing in the Archydro place  ...
Using ArcHydro 2.0 in a python script
MarkBoucher
Thanks! I looks like that was a while ago. I'll look into it.
ChristineDartiguenave
Basically you need to add "import ArcHydroTools" a the beginning of your script.
Then you can access the tools using ArcHydroTools.DrainageLineProcessing()
You can test it in the Python window in ArcMap.
Christine Dartiguenave
Esri Water Resources Team
