Convert WGS to UTM
12567
6
02-24-2015 08:44 PM
ShyamanthaSubasinghe
New Contributor III
I have number of City locations which collected from Google Earth. They are in WGS coordinate system. I need to convert them  into UTM coordinate system,separably. Is there any procedure to find respective UTM  zone for each city/ place in ArcGIS?
KishorGhatage
Occasional Contributor III
Step 1
1 .Navigate to the following location using catalog window / ArcCatalog
C:\Program Files (x86)\ArcGIS\Desktop10.2\Reference Systems
2. In a new arcmap session add "utm.shp" from the above location
3. Add your location layer ( which is in WGS)
4. Use Identify tool and click on the city
5. You will find zone in the identify window
Step 2
To reproject the data from WGS to UTM you can use Project tool (Data management).
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Hope this is helpful
Kishor
KishorGhatage
Step 1
Step 2
Kishor
New Contributor III
Thank you very much for your reply
I want to find out respective UTM zone for each cities..?
New Contributor III
Thank you very much Kishor Ghatage..It is very helpful for my work
NeilAyres
Just a picky terminology issue....
You can't actually have your data IN WGS84. Because WGS84, by itself, is not a coordinate system.
It is a datum & ellipsoid (& a geoid).
You can have it IN GCS_WGS84 (geographic, based ON the WGS84 datum / ellipsoid).
Then project it to a projected UTM zone based on the WGS84 datum.
New Contributor III
Thank you for explanation
MelitaKennedy
Esri Notable Contributor
An algorithmic way to determine the UTM zone is here and reproduced below. I originally cribbed it from Chuck Gantz.
ZoneNumber = floor((LongTemp + 180)/6) + 1;
if( Lat >= 56.0 && Lat < 64.0 && LongTemp >= 3.0 && LongTemp < 12.0 )
ZoneNumber = 32;
endif
// Special zones for Svalbard
if( Lat >= 72.0 && Lat < 84.0 )
if  ( LongTemp >= 0.0  && LongTemp <  9.0 )
ZoneNumber = 31;
  elseif
( LongTemp >= 9.0  && LongTemp < 21.0 )
ZoneNumber = 33;
  elseif
(LongTemp >= 21.0 && LongTemp < 33.0 )
ZoneNumber = 35;
  elseif
(LongTemp >= 33.0 && LongTemp < 42.0 )
ZoneNumber = 37;
  endif
endif
(I'm sure there are similar posts on GeoNet, but this is the first one returned by Google.)
