TIP: Publishing from a Google Spreadsheet
2905
02-19-2015 12:58 PM
KenBuja
MVP Esteemed Contributor
Three years ago, Esri published the blog post Using Google Docs in your ArcGIS Online maps‌. However, Google has since dropped support for CSV in the spreadsheets, meaning they can no longer be published as a CSV. Here is the work-around for this problem.
When you publish the sheet, you'll end up with a URL like this:
https://docs.google.com/spreadsheets/d/<KEY>/pubhtml?gid=197606809&single=true
Change that URL to this:
https://docs.google.com/spreadsheets/d/<KEY>/export?format=csv&id
