fnmatch or re?
4579
02-20-2015 09:47 AM
ToddHowell
I have a dynamic coded script that runs as a tool. It utilizes  arcpy.mapping to add some files to an existing template and then update the layer's symbology and name. I want to be able to differentiate between a couple different layers that have  the same geometry but different names. For example, there could be a Polyline file for a Assignment Break, as well as a Polyline file for a fire line file. This is the code that I have input so far (it isn't working).
code:
shapesList = arcpy.mapping.ListLayers(mxd_Update, "*_lyr", mainDataFrame_Update)
for shapes in shapesList:
    type = arcpy.Describe(shapes).shapetype.upper()
    name = arcpy.Describe(shapes).name.upper()
    if type== "POLYGON" and name== fnmatch.fnmatch(shapes, "*OLYGON*"):
        arcpy.mapping.UpdateLayer(mainDataFrame_Update, shapes, fire_perimeter)
        arcpy.SelectLayerByAttribute_management(shapes, "NEW_SELECTION")
        mainDataFrame_Update.zoomToSelectedFeatures()
        arcpy.SelectLayerByAttribute_management(shapes, "CLEAR_SELECTION")
        shapes.name = "Fire Perimeter"
    if type== "POLYGON" and name== fnmatch.fnmatch(shapes, "*NTENSE*"):
        arcpy.mapping.UpdateLayer(mainDataFrame_Update, shapes, intense_heat)
        shapes.name = "Intense Heat"
    if type== "POLYGON" and name== fnmatch.fnmatch(shapes, "*CATTERED*"):
        arcpy.mapping.UpdateLayer(mainDataFrame_Update, shapes, scatter_heat)
        shapes.name = "Scattered Heat"
    if type== "POLYLINE" and name== fnmatch.fnmatch(shapes, "*SSIGNMENT*"):
        arcpy.mapping.UpdateLayer(mainDataFrame_Update, shapes, assign_break)
        shapes.name = "Assignment Break"
    if type== "POLYLINE" and name== fnmatch.fnmatch(shapes, "*IRE*"):
        arcpy.mapping.UpdateLayer(mainDataFrame_Update, shapes, fire_line)
        shapes.name = "Fire Lines"
    if type== "POINT" and name== fnmatch.fnmatch(shapes, "*OINTS*"):
        arcpy.mapping.UpdateLayer(mainDataFrame_Update, shapes, fire_point)
        shapes.name = "Fire Points"
    if type== "POINT" and name== fnmatch.fnmatch(shapes, "*SOLATED*"):
        arcpy.mapping.UpdateLayer(mainDataFrame_Update, shapes, iso_heat)
        shapes.name = "Isolated Heat"
    else:
        print "no go fo sho tho"
A couple of basic questions... you can't use two (*) to grab a group of text from the middle of a string, correct? I can't really get my head wrapped around how I would use the m. functions in re to get this done... and I also can't use fnmatch because it isn't a filename, correct? Either way, I'm in over my head on this little bit
XanderBakker
Esri Esteemed Contributor
I didn't check the rest of the code, but you could also use something simple as:
if type == "POLYGON" and "OLYGON" in name:
BTW, next time, please use syntax highlighting for your code (see: Posting Code blocks in the new GeoNet )
XanderBakker
