bug in draw tool (Draw.POLYGON) ESRI JS API
3025
02-18-2015 09:20 AM
Roy_A_Justo
When using  esri/toolbars/draw, this is what happened if the drawing feature used is a polygon Ex. toolbar.activate(Draw.POLYGON)
Once activated the toolbar, on mouse down you start drawing, and with each click you shape the polygon at will. But if in the second click, where you have drawn a line and not a polygon yet, you decide to double-click instead of one click, then the toolbar stop drawing, and draw-end fires, however the result geometry is not a polygon as this feature expect, it is a line in this case. Then you get an error (see image )Capture.PNG
I don't think this should be an error.
Is there anyway i cant prevent this error from showing up in the console?
thanks!
roy
